CRX tune up
Old Feb 28, 2010 | 03:00 PM
JacksonD's Avatar
Default CRX tune up
So ive been getting poor fuel mileage lately, and am also parting together a turbo kit for my 90 crx si (200k, rebuilt 15k ago) and figured this is as good a time as any to do a tune up. I have so far changed my plugs, oil, oil filter, coolant, and thermostat. I plan on changing my o2 sensor and fuel filter, is there anything else that should be checked? ( i also plan on replacing the timing belt)
Old Feb 28, 2010 | 03:18 PM
lunalink's Avatar
Default Re: CRX tune up
water pump, gasket kit check for old rotting hoses. check ur valves ..lol. you know the usual
Old Feb 28, 2010 | 05:28 PM
HondaPartsHero's Avatar
Technical Hero
plug wires
pcv valve
distributor cap and rotor
check ignition timing
Old Feb 28, 2010 | 05:31 PM
JacksonD's Avatar
i was also planning on running a compression test as well
jdm_sir2
Sep 3, 2008 04:25 PM
lmike6453
Aug 1, 2007 02:07 PM
bluelude2.3
May 25, 2007 11:58 AM
B2FiNiTY
Jul 19, 2003 12:37 PM
Behan
Jul 8, 2003 02:09 PM
