Suspension & Brakes Theory, alignment, spring rates....
92 Civic CX Front Sway Bar?
Old Feb 28, 2010 | 07:31 AM
EdSales's Avatar
Default 92 Civic CX Front Sway Bar?
I have a 92 Civic CX. I am aware that you are unable to mount a Rear Sway Bar without LCA's due to the fact that the OEM LCA's for the CX do not have mounting holes, but what about a Front Sway Bar? And if not for the Front, what Front LCA's do you recommend?
Old Feb 28, 2010 | 08:47 AM
kristo's Avatar
Loved
Default Re: 92 Civic CX Front Sway Bar?
Are you sure you don't have a front sway bar now? (I'm not accustomed with US models)
If not just swap your front LCA's with models which do have an endlink mounting hole: OEM EG or ITR will do, they have the same dimensions, only endlink mounting hole differs (ITR style is to be preferred).
Read this.
Of course you could also buy Spoon's Competition Suspension Arm Kit
wurmhole
May 29, 2019 06:24 PM
EdSales
Suspension & Brakes
Sep 9, 2010 02:17 PM
EdSales
Aug 2, 2009 08:23 AM
Notorious_T
Dec 8, 2008 05:41 PM
KF_S2000
Nov 21, 2003 09:07 AM
