intermediate shaft and axles?
done a search...cant find what i need.
i have a 94 hatch....getting the ls-vtec...b-18b,hydro trans...now the question....
i have 90-93 axles...and need the intermediate shaft.....do i use the 90-93 shaft or do i need the 94 and up shaft, and which gen should be used to get everything "right" 90-93 or 94 and up.
need to find out asap...as the swap is supposed to happen this weekend...
thanks....
thanks....
i think you will have to use a int. shaft that matches your engine.
if this is the case you might also have to match the axles to the int. shaft.
i dunno but, i have never done this...
still, if you have a 94 hatch - why do you have 90-93 axles???
t..
t..
the axles are brand new....and i only paid $50 for both....so i was told that if i use the 90-93 axles... i need to use the 90-93 shaft....same with the 94 and up....
Straight outta SCC... 90-93 int shaft. 90-93 axles. 94 and up integra GSR shift linkage.
Its in October 01. Now that i think about it it was a 1st gen b16, but I dont think that would matter.
hth,
[Modified by Monty, 8:17 PM 9/8/2002]
hth,
you need 90-93 shaft if you use those axles. 94+ shaft will not work, look here...
http://www.hasport.com/B16axles.htm
this is 4g tech info, but it still applies
HamiltonRex
Feb 22, 2006 03:58 AM
