Here's my b20 vtec project
i already have the complete and block, i'll be getting other part in the next week.
-b20b stock internal
-b16 head no p&p
-skunk2 intake with 70mm tb (all is port match)
-hondata intake gasket
-hyteck try Y headers
-2.5" exhaust straight
-tuned with hondata s200
i'm hoping for 185 whp an 145-150 tq
do you think it's a good goal.
-b16 head no p&p
I dont see this block lasting very long with stock block. I have seen many stock head b20 vtec's put down 180whp with ebay bolt ons
this is my setup........
gsr head with type r springs and new itr lma's
replace all seals and gaskets
arp head studs and rod bolts
acl rod bearings
new mls head gasket
obd2 gsr water and oil pump
new gsr timing belt
b20b block with rs itr pistons and rings
Kms shot peen rods
Kms 65 mm ported tb and port matched stock gsr mani
hone cylinders
blox adj cam gears
adj fpr
havent picked out a header yet
2.5 in straight exhaust
NGK V-power BKR7E spark plugs
Magnetic drain plugs
hondata/vafc tune
Im hoping this setup will get me 180-200 whp and great reliablity!
acl rod bearings
new mls head gasket
new gsr timing belt
Kms shot peen rods
hone cylinders
blox adj cam gears
adj fpr
hondata/vafc tune
i don't bother about the b20 block, i'm not going to keep it for 4 years. my red line will be around 7400rpm with a good tune, i don't know why you'R saying it will not last.
Hp number is realistic, but the torque might be a little steep.I just did a duno run on a low reading dynojet and made 204whp and 143 tq.B20 block / gsr head12.5:1 cp ratio S2S2 cams (gears at 0 degrees)S2 pro IMS2k Throttle bodyRMF replica header.2.75" exhaust3" ITR cold air intakeBasically went to get tuned, did one short pull. Added 10% fuel accross the map.. Did one full pull.. Made the 204whp. Then the brakes would not turn off on the dyno. Apparantly the solenoid fried. So I will be back there next week to finish the session.
-b16 head no p&p
-b16 head no p&p
importeclipsegst
Jul 15, 2010 08:28 PM
but is my goal realistic???
