Swapping regular with VTEC engines
Old Feb 27, 2010 | 02:49 PM
Stakhov's Avatar
Icon6 Swapping regular with VTEC engines
Hi, I got a Honda Accord 1996 and I feel like I will have to swap the engine on it. I have VTEC right now.
I couldn't find any information if I can get a regular 2.2L engine and connect VTEC from my engine to it. Will that work? And also, does it have to be 1996 only or some others might fit too?
Old Feb 27, 2010 | 06:06 PM
tamadrummer1120's Avatar
Default Re: Swapping regular with VTEC engines
what you have in your car is f22b1 engine. the 2.2l vtec version. you can use the f22b1 from a 96 or 97 as they are obd-2. the f22b1 from a 94 or 95 would work but a lot of wiring is required because that engine and the wiring harness (as well as ecu) is obd-1.
Old Feb 27, 2010 | 06:21 PM
Stakhov's Avatar
Thanks, tamadrummer1120 )
Can h22a go in it too? too much wiring?
Old Feb 27, 2010 | 06:28 PM
sure it can
you want the obd-2 one though (for less wiring). and if you stick with obd2 it is not much wiring. use the search function, and you will find countless threads on the swap.
Old Feb 27, 2010 | 06:38 PM
GEIJIN's Avatar
any issue with swapping in a 99 accord vtec motor into a 97 chasis? it's still obd2 right? same wiring harness pretty much?
Old Feb 27, 2010 | 08:27 PM
nus_dogg's Avatar
99 Accord F23A1 VTEC motor will work except that the IACV is different, so you'll need a IACV adapter plate to retain your 2-wire IACV. B1 & B2 engines have different IM compare to F23A.
Old Feb 27, 2010 | 08:53 PM
Stakhov's Avatar
Which one? F23A1 with ULEV or w/o ULEV? Does it make any difference?
Old Feb 27, 2010 | 09:50 PM
GhostAccord's Avatar
F23A1 is not a ULEV. That would be an F23A4 that is the ULEV.
Old Feb 27, 2010 | 10:36 PM
Stakhov's Avatar
Got it... Thanks.
I guess the next question would be if I will need to change anything else to make it work (except IACV adapter)? Is it gonna go together with my transmission etc?
Lucas_Green
Aug 19, 2013 09:31 PM
90matthf
Jan 22, 2009 12:53 PM
MS99k
Feb 6, 2006 02:05 PM
The_In_Kid
Aug 3, 2002 03:59 PM
