Integra Failed Emissions - High NOx! please help
Hey guys, I'm searching around as I write this thread for an answer, but I really need to know ASAP. I have a 1992 Integra RS, 5 speed with a B18B1. I took the car for a smog/emissions test today, and the car passed on everything but the NO ppm (NOx) section. The limit is 505 and my car read 2051. Anyone know what could cause such a high reading? I just put a skunk2 cat back exhaust (used-good cond.) and a magnaflow 2" cat on (new). Everything else passed with flying colours, but the NO ppm failed by quite a bit.
ANY HELP WOULD BE GREAT!
here's a copy of my readings:
I did the seafoam too. The stuff is pretty cool. Other things to do: new o2 sensor, new cat, clean the egr valve, clean the air filter, new pcv valve. Before my checks i also put in new plugs. Good luck man. I've also heard that you can run your tank to nearly empty, then pour in 16oz of pure (or 99%) of isopropyl alcohol and take it to the test immediately. supposedly it burns cooler.
Oh god no. No alcohol please.
Check ignition timing. EGR but did the B18A have EGR... I'm drawing a blank. And get rid of the Magnaflow cat and never buy a Magnaflow cat again. They're pure crap. Just get whatever cat the exhaust shop gives you. "High flow performance" cat is a complete joke. Cats don't cost you any power until you're making ultra-ridiculous power.
thanks for the suggestions guys! I've read a few places that only the automatic transmission Integras have EGR valves...true? Also, the mechanic poured a product similar to Seafoam which he said works great. so I'm going to go back and test again on monday and see how that goes. any other help is appreciated too!
hey guys....so I retarded the timing and the car still read too high (800-900). We even retarded it as far as it could go, and still no luck. I bought plugs last night, so I'm gonna throw those in. But I'm a little stuck...not sure where to go from here. Any other help?
Set ignition timing to factory specs. Pour 3/4 of a can of sea foam through the brake booster line. Pour the rest in the gas tank. The next day put in some new NGK V-Power plugs. You may also need a new O2 sensor.
If you still fail then, its time for a new catalytic converter. I have been using the Magnaflow high flow cats for years and never had a problem with them. Sure they don't last as long, but they are nearly the price of a factory one.
But I am almost 100% certain if you use the Sea Foam correctly, you will pass emissions.
Sounds like you don't know how to do the sea foam trick, so I will tell you:
1. Start the car.
2. Take the hose off the brake booster that runs from it to the back of the intake manifold.
3. Get a small funnel that fits inside the hose.
4. Have a friend sit inside the car and keep the rev's above 1000-1500. Tell him DO NOT let the car stall when you are pouring the sea foam in. It will want to try to stall if the revs are not kept up.
5. Start pouring the sea foam into the funnel at a slow and steady pace. Not too much because you don't want to flood the engine. Continue pouring until you've empty 1/2-3/4 of the bottle. Then shut the car off and wait 15 minutes.
6. 15-20 minutes later go take your car for a very spirited drive. Be sure to get on it and drive it hard. Lots of red line pulls. Your car will be smoking A LOT. Do not worry, nothing is wrong. Your engine is cleaning itself. Continue driving hard until there is no more smoke coming from your exhaust.
7. Change your oil and change your spark plugs.
8. Pour the rest of the sea foam into your gas tank and drive it for a day or two, then go back through emissions.
9. If done correctly and your catalytic converter is working, you will pass.
1. Start the car.
ok man for the most part you need to be looking at your plugs.wires.cap and rotor. vacoom lines and put the stock cat back on. if you want more power that way you get larger piping and a better muffler. oh and if your temp is too hot that messes with a lot of things. but if your check engine light isn't on your o2 is fine. and DO NOT USE PURE ALCOHOL.ever.
Threads like this make me nervous to move to Nevada....i've never had to do ANYTHING emissions related in ND. Hell, i dont even have a catalytic converter anymore. Good luck with the Sea Foam method...odd, but if it works, whatever
I picked up ngk v power plugs. Gonna put them in then try the sea foam trick mentioned above. I really hope that works...if not I dunno what to do. Engine temp is normal...no engine light on. But we'll see how it goes...also, I've read that my integra wouldn't have an egr...is this true? Its a 92 rs coupe with a b18b1 from a 95 integra I believe.
My engine temps seem normal too.Set ignition timing to factory specs. Pour 3/4 of a can of sea foam through the brake booster line. Pour the rest in the gas tank. The next day put in some new NGK V-Power plugs. You may also need a new O2 sensor.
1. Start the car.
1. Start the car.
Lol, the whole reason I bought the car THIS YEAR is so I could drive it...THIS YEAR. I need a car on the road now, not in 2 years lol. Thanks anyway haha
I think the cats fine, can't really remember what it looked like inside. like i know its not hollowed out or nothing. I bought it off a guy on the web. He said it was brand new, never used. I know it was never used because you could tell, but im 99% sure the internals were normal.
I have done emissions with a stock gutted cut and I have bought an aftermarket cat and also failed for the same thing without the stock cat. The aftermarket is not the same also hence the "high flo", I would just use a stock cat to pass then you dont have to worry for 2 years, happened to me. Js.. Good luck
So I did the sea foam method mentioned above, replaced the plugs with NGK V-Powers, and drove the hell out of it. Did the E test when the car was nice and hot...Still no luck
I even retarded the timing right back, and the NOx read around 1,200 (limit-505). I checked out the vacuum lines, and they seem fine. I dunno where to go from here...any help or suggestion guys. I'm considering replacing the O2 sensor, but wouldn't the engine light be on if there was something wrong with it?
any help is appreciated!
(here's a pic of the test when the timing was retarded, and after i did the plugs/sea foam)
I even retarded the timing right back, and the NOx read around 1,200 (limit-505). I checked out the vacuum lines, and they seem fine. I dunno where to go from here...any help or suggestion guys. I'm considering replacing the O2 sensor, but wouldn't the engine light be on if there was something wrong with it? any help is appreciated!
Do both the B18A1 and B18B1 only have one O2 sensor (pre-cat)?? My car doesn't have an O2 sensor on the Skunk2 cat back exhaust or Magnaflow cat I installed, is this normal? I installed the cat and exhaust system myself, and there was no O2 sensors for it. I'm just wondering because it may be possible that the B18B1 is meant to run with two o2 sensors (pre-cat/post-cat), but 92' integras with A1's only came with one before the cat. What do you guys think?
Yes the only have one O2 sensor located in the header pipe just behind the oil pan. Mine had an A1 in it till I installed a B1 about 18 months ago due to excessive oil consumption.
It appears that you made quite a bit of progress between the first and second test but just need one more nudge to get a pass. I would be suspecting the cat myself but unfortunately it will cost a few bucks to test the theory. Wish I has a spare stock cat sitting around to offer you.
I had my 93 teg tested today and it failed the NOx with a 773. I'm located just south of you so I'm fighting the same limits (505). I'm going top attempt the same items as you to see if I can get the few points I need to get another two years out of the old girl.
Sounds like the timing made the difference and it was quite a big difference. It wouldn't hurt to throw some methyl hydrate in there and have another go. The place I went today offered two half price retests to see if I can get the numbers down, I hope you were offered the same in Ottawa.
well the very first test I did nothing to the car, just drove it in and tested it. That same day, i retarded the timing and tried it and it read around 1,200. I did the sea foam, new plugs, retarded the timing and it still read 1,200. so to be honest, nothing has really changed. Thanks a lot though
Retarding the timing will also bump emissions...
Try to find someone with a stock cat that will let you borrow it for a day.
Ok, I'm starting to think that my motor may be an OBD2 engine (converter to OBD1) so it is looking for two O2 sensors...does this sound possible? I'm 90% sure when I looked at the stamps on the head, I saw (9/8) which would mean 1998...I'll have to double check, but does this sound like it could be possible? Maybe my motor is searching for a second O2, so everything is all over the place. I'll also check to see what ECU I have in.
