motor question need help!!!!!!!
I put a used motor in my car(90 civic dx hatch 1.5l) and even when starting it in the morning the temp gauge shoots to hot and the check engine light comes on and i can't figure it out....can any one help me with this??????
so the problems happen when you put the key to on? Or when you let the car Idle? I believe one of your harness grounds are loose or not bolted down and or your thermostat is stuck.
all i have is the little blue wire that has 2 pine holes for ecu and yea it does it when i turn the key on then it will idle between 1000 and 1500 rpms sometimes and when i turn the key on in the morning without starting it the temp will be stuck on hot
Doodoo
19
Jun 29, 2016 04:21 AM
1990hf
Nov 28, 2008 08:38 AM
jdmsiR20
16
Aug 10, 2006 05:09 PM
