dc5 brembo on dc2
Old Feb 27, 2010 | 09:06 AM
fishpimp's Avatar
Default dc5 brembo on dc2
has anyone done it,i think its possible,anyone can shed some light?
Old Feb 27, 2010 | 10:02 AM
Nibor's Avatar
Default Re: dc5 brembo on dc2
Let there be light.
Old Feb 27, 2010 | 03:03 PM
Dogginator's Avatar
Daisy... Daisy...
DC5 Brembos on DC2 ITR?
dc5 brembos
Are just two examples. This can be done. Wheel choices are very limited.
Old Feb 27, 2010 | 03:21 PM
94rs-turbo's Avatar
I read the threads. Sounds useless in my opinion,
Old Feb 27, 2010 | 07:41 PM
fishpimp's Avatar
seems like no one actually done it
Old Mar 1, 2010 | 06:35 AM
bluebomber's Avatar
Information Leafblower
Here is some info I found. The guy in this thread has an EG, but it has DC2 5 lug on it, and he claimed to use DC5 brakes on it.
http://www.k20a.org/forum/showpost.p...9&postcount=15
Here's some more info on the subject:
http://www.team-integra.net/forum/di...PagePosition=1
I know you're going to need to change the calipers, rotors, hubs and knuckles for sure. You'll also need 17s at least (some 16s might fit), and probably extended wheel studs. Beyond that, I don't know. I'd personally go for Legend or NSX brakes, as they are both two-piston and will fit directly with a milled 28T bracket. You can fit under many 15s with this setup, and use OEM pads too.
If you have more questions, you should talk to user 'BE2' on here.
Old Mar 1, 2010 | 07:57 AM
Dr. DC2's Avatar
i made this EXACT SAME THREAD less than 3 weeks ago. yes it can be done. contact sheekdude. he used spoon monoblock DC5 calipers on his ITR. Its the SAME parts minus the calipers! its a LOT of work and wheel choices are VERY limited like the DOGGINATOR said! I considered this but for for 1/2 the price of the conversion you could buy wilwoods! and rock just about any wheels!
Old Mar 1, 2010 | 08:44 AM
highroller54's Avatar
Installing spoon monoblocks are nothing like installing dc5r calipers. Completly different.
Old Mar 1, 2010 | 08:46 AM
Dr. DC2's Avatar
From what I remember thats what sheekdude told me he had on his R. IDK, its just what I heard. I know that its not worth installing the DC5 Brembos because dollar for dollar you could have Wilwoods/spoons/mugens/nsx/legend.
Old Mar 1, 2010 | 08:55 AM
Pretty sure he has monoblocks, thats a easy swap. Brembo dc5r's do not bolt up to a dc5 knuckle, thats were the confusion is comming in I believe.
Old Mar 1, 2010 | 08:56 AM
Dogginator's Avatar
Daisy... Daisy...
Check out the diagrams from my old FS thread.
New Brembo DC5R (RSX) Front 4-piston calipers with pads and mounting hardware
These calipers weigh 9 pounds each with pads.
Old Mar 1, 2010 | 09:04 AM
Dr. DC2's Avatar
speaking of confusion i think you meant to say DC2 knuckle
Old Mar 1, 2010 | 09:08 AM
Dogginator's Avatar
Daisy... Daisy...
Yes they do.
Old Mar 1, 2010 | 09:14 AM
bolt up yes, they are not spaced corectly to clear the dc5r rotor though.
Old Mar 1, 2010 | 09:27 AM
Dogginator's Avatar
Daisy... Daisy...
An S2000 rotor has potential.
Old Mar 1, 2010 | 09:31 AM
Dr. DC2's Avatar
which is what he told me he was running. and i never said it BOLTED up.
giperbolic
Mar 30, 2010 07:47 AM
DCMikey
Mar 18, 2009 04:44 PM
odishaw
Suspension & Brakes
May 7, 2008 02:37 AM
SuckMyDOHC
Sep 11, 2004 10:44 AM
SuckMyDOHC
Sep 9, 2004 10:31 PM
