B20 Vtec head
Old Feb 26, 2010 | 06:34 PM
JDMEJ!'s Avatar
Default B20 Vtec head
I was wondering if you use a GSR head for a B20vtec can it be use for a regular GSR block if you change your plans down the road even thought you have the oil plug in from a Golden eagle kit?
Old Feb 26, 2010 | 06:48 PM
thumper64's Avatar
Default Re: B20 Vtec head
Yes you can, you just have to remove the plug from the head and plug the hole where the hose goes in.
The better, albeit more expensive, is to get a GSR block and get it sleeved, bored to 84mm and run a LS crank. You'll get the same 1.97 Liters as a B20, but the block is stronger and you can also safely boost it. If you aren't a fan of turbo, ride in a car that is and you'll want to do it to yours.
Old Feb 26, 2010 | 06:54 PM
JDMEJ!'s Avatar
I was thinking about doing that to my GSR block but i have a b20 not being used and don't have all that much money to do so with my GSR block. I thought that plug would get stuck or some shop weld it in so there isn't any leaks that's why i ask.
Old Feb 26, 2010 | 08:12 PM
noremorseracing's Avatar
the plug in the bottom of the head is threaded in it comes rite out, then they take off the plug on the back of the head which is plugable again. simple and quick
Old Feb 26, 2010 | 08:29 PM
300whpej's Avatar
how well do ls cranks hold up above 8k?
Old Feb 26, 2010 | 10:43 PM
thumper64's Avatar
The crank itself will hold like 500hp, it's the rod bolts that usually are the weak spot. If you balance everything, it should hold ok. Piston side loading becomes more of an issue with longer strokes though.
x_doug-x
Oct 28, 2010 12:21 AM
EG6 Love
Feb 24, 2010 05:01 AM
bsemeyn
Sep 30, 2003 06:15 AM
