SOHC ZC won't start
Old Feb 26, 2010 | 04:46 PM
twoshort108's Avatar
Default SOHC ZC won't start
Well guys, I guess I will be more of a regular here than I expected...
89' CRX, SOHC ZC swap, Manual Transmission.
Recently I had a problem with my car dying while driving, and not starting back up for about five minutes. People on these forums gave me a few ideas, which I am thankful for, and with them I got the problem fixed.
So I drove today to pay off some bills, and when I came back out to my car, it would NOT start. I waited and waited with no results. It keeps turning the engine, but it will not start. After doing some diagnosing, we found out that I am NOT getting any spark. I have changed all of the following parts within the last week:
Distributor Cap
Distributor Rotor
Spark Plugs
Fuel Filter
Ignition Coil
Radiator Hose
And we had the ignition module tested, which they said it was fine.
You may be asking why the radiator hose matters, but while inspecting the engine, I saw that there was a leak coming from the hose, shooting fluid towards the distributor cap. I don't know if this is relevant, but we fixed the hose and cleaned and inspected the cap.
Once again, I am getting no spark. I am completely stumped, and as usual, any help will be appreciated.
Old Feb 26, 2010 | 05:07 PM
EFRue57's Avatar
Default Re: SOHC ZC won't start
do you have a multimeter? if so, check if you are getting power to the distributor.
Old Feb 26, 2010 | 05:56 PM
Yes, we do have a multimeter, and my dad said we were getting power to the coil, but I'm not sure if we were getting power to the distributor itself. It is still pretty cold out here in Kansas, on top of it being dark. I will give it another shot tomorrow. In the mean time, I will ask him what exactly he checked for power.
Old Feb 27, 2010 | 07:27 AM
Tyson's Avatar
the only thing left to check is the ignitor inside the distributor.
Old Feb 27, 2010 | 10:48 AM
Is that a single part? Or would I need to get a whole distributor?
Old Feb 27, 2010 | 10:52 AM
romierome's Avatar
its a single part.
i could be the ignitor or the coil.
Old Feb 27, 2010 | 02:48 PM
Is the ignitor the same as the ignitor module? If that is the case then I had the current one tested, which they said it was still good. I also changed out the coil.
Old Feb 27, 2010 | 10:08 PM
ba_reefer's Avatar
im pretty sure its the igntion coil http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Old Feb 28, 2010 | 07:49 AM
Well in that case, yes, I have changed the ignition coil.
Old Feb 28, 2010 | 01:36 PM
Just replaced the main relay and it started right up. The old one was corroded pretty bad, and basically just nasty over all
acmoc
Feb 3, 2010 09:43 AM
dmeconitas
Dec 10, 2009 04:26 PM
IP RACING
Jan 15, 2007 07:10 PM
juanb
May 30, 2004 05:54 PM
civic2299
May 11, 2002 06:45 PM
