double din headunit. to fit in 99-00. cage
Old Feb 26, 2010 | 03:15 PM
c|rop3asy==[]'s Avatar
Default double din headunit. to fit in 99-00. cage
how do i make my kenwood ddx6019 fit flush into my console? do i need a cage/chassis or something? how do am i suppose to install this, take apart the center console? when i try to put it in, it kinda slides right through easily, not the same as a regular 1 din hu would.
Old Feb 26, 2010 | 05:32 PM
wes7side5o's Avatar
Default Re: double din headunit. to fit in 99-00. cage
Pretty easy just take out the center piece and you see the holes on the side. That is for you to screw the deck into the center piece. Make sure you use the screws provide by the deck. If you do not have it then find screws that wont screw in too far. You don't want to short out deck by screwin in too much. After you put it all back together the trim on the outside of deck should make it look pretty. haha/ GL
Old Feb 27, 2010 | 10:33 AM
do i need some kind of kit? it seems to have about 2cm of space on four sides, and doesnt sit flush and snug
Old Feb 28, 2010 | 04:38 AM
audioroach's Avatar
Yes you do...depending on what you want the final result to look like or if your unit is used and didn't come with all the trim bezels.
Luckily both metra and schosche have a filler kit for your car.
Old Feb 28, 2010 | 06:09 PM
idgf77's Avatar
evryone makes parts for that car....i wish all ddin installs could b that str8t forward..
Old Feb 28, 2010 | 07:14 PM
DynastyRacer22's Avatar
you need metra part number 95-7801 or 99-7801 with side mount brackets so it doesnt slide out
http://www.metraonline.com/fitl.aspx
slowslow
Aug 23, 2009 08:30 PM
1991hb
Apr 11, 2007 07:45 PM
VTECej1
Aug 8, 2004 10:07 PM
cd5_2NR
Audio / Security / Video
Apr 12, 2004 05:52 AM
Gump
Aug 12, 2002 12:15 PM
