wheel issues
Old Feb 26, 2010 | 02:58 PM
miggy23's Avatar
Icon6 wheel issues
i have a ? i recenlty put some rims on my ef and after a few days It started to vibrate from the steering wheel it gets really bad when i go over 55 does anyone know what it could be i was thinking maybe my wheel bearings have messed up please help
Old Feb 26, 2010 | 03:47 PM
EFRue57's Avatar
Default Re: wheel issues
i would guess that it is either the wheels and tires not being balanced correctly. if it didn't happen with your last wheel/tire combo, then i wouldn't think it would be your wheel bearings.
Old Feb 26, 2010 | 09:26 PM
miggy23's Avatar
so the wheels are probably not balanced right and no it didn't do that with my old setup
Old Feb 26, 2010 | 09:55 PM
projekt90ef's Avatar
either that or just need new tires
Old Feb 26, 2010 | 10:25 PM
miggy23's Avatar
I just got the tires so I'm thinking they might not be balanced right so I'm gone take it to my tire shop and see what they tell me I hope its nothing major I have to fix
Old Feb 26, 2010 | 10:29 PM
if ur tires are under warranty sumtimes they balance for free...even if not its not an expensive fix
Old Feb 27, 2010 | 06:45 AM
scottmog's Avatar
first off, what rims and wheels are u running?
Old Feb 27, 2010 | 08:11 AM
miggy23's Avatar
15 195 55 why do you ask toro wheels toyo tires got the wheels off craigslist
Old Mar 1, 2010 | 02:22 PM
miggy23's Avatar
would anything else cause this issue could it be alignment related please help taking my car to get the wheels checked out
Old Mar 1, 2010 | 03:10 PM
zrickety's Avatar
check the center of your hubs and the back of the wheels...you might have some damage that is preventing the wheels from sitting flat. this happened to me and eventually a stud broke and the wheel almost fell off!
Old Mar 1, 2010 | 03:28 PM
scottmog's Avatar
if u dont have an alignment id advise doing that first, then troubleshooting. that is usually the problem
Old Mar 1, 2010 | 03:54 PM
roadsqueegy95's Avatar
id deff get them rebalanced, and get a alignment done. if that doesnt work, maybe new tires or id say bent rim maybe?
Old Mar 1, 2010 | 04:14 PM
miggy23's Avatar
I don't think its a bent rim they where brand new I have only had them on for maybe about 1 week and a half but I'm gone get them rebalanced and do an alignment ill keep you guys posted thanks for all the suggestions and help
Old Mar 5, 2010 | 02:43 PM
miggy23's Avatar
So I m getting my wheels balanced the guy is telling me I need some wheel hub rings because the wheel won't sit right on my hub does anyone know if this is true
Old Mar 6, 2010 | 04:39 AM
Sikocivic's Avatar
Yes this is true.
Old Mar 6, 2010 | 03:58 PM
miggy23's Avatar
So he odered the kit for me and also got the problem fixed 1 of my front wheels had a lump on it I still need my alighnment and I'm still gone put that kit thing on and I am finally gone get my swap done at the end of this month zc single cam no more dpfi for me
Old Mar 6, 2010 | 04:04 PM
BiG ChOr!Zo's Avatar
zc sohc just like mine FTW...make sure you source a d16a6 complete intake manifold to use on the zc motor to be emissions legal...!!!
Old Mar 7, 2010 | 06:37 PM
miggy23's Avatar
already have it on the engine got it from the same guy I got the engine from how can I know if its a d16a6 intake manifold the guy says it is but is there a way I can check it and how does the zc run for you pulls hard I hope
sfcivicex
Aug 11, 2013 10:25 PM
mikeunreal2
Jun 3, 2007 12:12 PM
gyrmaersk
Apr 21, 2006 12:57 AM
Turbo Powa
25
Apr 25, 2003 02:32 PM
performula
12
Sep 11, 2002 07:49 PM
