type r calipers
Old Feb 26, 2010 | 10:21 AM
futureracecar's Avatar
Default type r calipers
i was just wondering if i could use type r calipers, mounting bracket, and pad on a gsr brake setup? any help would be great
Old Feb 26, 2010 | 10:31 AM
Zappythebum's Avatar
Default Re: type r calipers
I read something in superstreet along those lines, you should be able to use the type-r calipers on the gsr if swapped properly. Let me see if I can dig thru the magazine again and find some info for you.
Old Feb 26, 2010 | 10:43 AM
cool thanks man
Old Feb 26, 2010 | 10:57 AM
super jdm yo's Avatar
you'll need to shave off ~3mm depending on what rotor you use from the mounting bracket itself to have them mount up to the knuckle. hope this helps good luck
Old Feb 26, 2010 | 12:12 PM
racebum's Avatar
and you'll need to redrill a prelude vtec rotor from the mid 90s. personally i'm on this exact setup with axxis ultimate pads. great street/track combo for mild hp levels. i have zero fade issues with a stock jdm itr drivetrain. with stock gsr brakes, autocross was doable but lap days or crazy back road nurburgring runs would bring on fade even with hp+ pads
exies
Suspension & Brakes
Dec 5, 2014 03:30 PM
JMac Dc2
Suspension & Brakes
Feb 25, 2011 07:45 PM
jakfrost84
Suspension & Brakes
Apr 21, 2009 09:47 PM
jakfrost84
Apr 20, 2009 12:31 PM
TypeSH
Mar 17, 2003 11:11 PM
