no sound coming out my new speakers!!!!!
Old Feb 26, 2010 | 10:14 AM
Feli's Avatar
Default no sound coming out my new speakers!!!!!
i connected my speakers in the front doors of my 88 civic & when i turned the car & radio on no sound came out....what can be wrong??
Old Feb 26, 2010 | 04:04 PM
c|rop3asy==[]'s Avatar
Default Re: no sound coming out my new speakers!!!!!
maybe you got the "+" and "-" backwards
Old Feb 26, 2010 | 05:28 PM
wes7side5o's Avatar
if you got ur wires on the wrong way it still will give out sound.
Do you have it connected to an amp or is it going straight to your deck? If it has an amp I can give you more possibilities of what's wrong.
If not then
1. It could be one of your wires fell off or not connected all the way behind the deck/speaker.
2. It could be that your speaker/channel on deck is completely blown.
3. It could be you hooked it up wrong.
I suggest pulling out your deck out and hook the wire straight from the speaker to the deck so you know if the speaker works or not. If it does that means your wire in your car from the deck to the door is cut somewhere.
Solution: You can find where it's cut n reconnect it or you can run a new wire from your deck to the door speaker.
Good luck and lmk if you have any more questions.
Old Feb 27, 2010 | 12:58 PM
Feli's Avatar
not connected 2 the radio harness? ima check that **** out....but its both doors that aint workin....ima see
Old Feb 27, 2010 | 01:12 PM
wes7side5o's Avatar
Other possibility could be that you took two positive wires to one door side and two negative wires to the other door.
Old Feb 27, 2010 | 09:21 PM
baller status's Avatar
One of the terminals on your speakers is touching the metal of the door. Pull the front speakers out and set them on something with the wires still attached and see if they play. Then install them with the sound still playing and when you tighten them down the sound will go away (radio will go into protect mode). Get an air saw and trim the door metal and use a mounting bracket to space the terminals away from the door frame. Rotating them where they have the most clearance can also help.
Old Feb 28, 2010 | 07:52 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
It is not too uncommon for the terminals or tinsel leads on aftermarket speakers to come in contact with the doors sheet metal, a little trimming/notching will solve that problem. 94
Old Feb 28, 2010 | 08:09 AM
ken9's Avatar
I still think the speaker might still work. I did say he have his speaker wires hook up wrong with the other wires..
Old Feb 28, 2010 | 06:03 PM
idgf77's Avatar
check baller status-quick thinking
Outlaw-Hondaz
Apr 5, 2011 09:41 AM
mayfly
Audio / Security / Video
18
Jul 27, 2009 11:06 AM
Dead CIVIC
Jun 2, 2009 12:01 PM
pbcdb
Jan 4, 2004 12:39 PM
itsJDMyo
12
Nov 18, 2003 04:37 AM
