Are the Si and Hf harness interchangable? (crx)
Old Feb 26, 2010 | 08:09 AM
lunalink's Avatar
Default Are the Si and Hf harness interchangable? (crx)
thinking of picking up an Hf CRX harness to mate with my Si under dash harness.
Would it be a plug-N-play or do i need to de-pin/strip stuff?
my main concern are the actual connectors.( giant white plug and brown plug)
if anyone can point me in the right direction or give me any information i would really appreciate it.
thanx
Old Feb 26, 2010 | 08:21 AM
t_ank's Avatar
Default Re: Are the Si and Hf harness interchangable? (crx)
id just get an si harness
Old Feb 26, 2010 | 08:25 AM
lunalink's Avatar
I know, but this one is pretty cheap and seeing as its also Mpfi i just wanted to see if was worth the buy.
Old Feb 26, 2010 | 08:31 AM
t_ank's Avatar
well good luck
Old Feb 26, 2010 | 08:56 AM
dacrxguy's Avatar
The plugs will mate but they are not interchangeable unless you start depining
Old Feb 26, 2010 | 08:58 AM
dacrxguy's Avatar
ps i think i have the dx pin-out too if you need it
Old Feb 26, 2010 | 09:05 AM
lunalink's Avatar
^ sweet if you can that would be awesome!
Old Feb 26, 2010 | 09:14 AM
lunalink's Avatar
since I'm doing the same thing(but with Hf engine harness and Si under dash harness) i would just reverse the instruction right?
just remove the EGR wire?
Old Feb 26, 2010 | 09:42 AM
jlicrx's Avatar
not quite - do this:
Old Feb 26, 2010 | 09:51 AM
lunalink's Avatar
thanx both of you for all of your help.
seeing as i might go buy the harness when i get off of work
Old Feb 26, 2010 | 12:46 PM
dacrxguy's Avatar
i got the si to hf chart from jlicrx along time ago too
Old Feb 26, 2010 | 12:56 PM
lunalink's Avatar
lol.
thanx for the info guys i'm going to do this tomorrow
K20AllMotorEF8
Feb 11, 2012 11:38 AM
hondaex99
Oct 29, 2009 09:19 PM
Pnoyej6
Apr 26, 2007 05:55 PM
Boost Junkie 83
16
Apr 2, 2007 06:28 PM
CrxBoy6690
Apr 3, 2006 06:27 PM
