Another "will this stupid idea work?" thread
Old Feb 25, 2010 | 10:07 PM
Masterbeavis's Avatar
Default Another "will this stupid idea work?" thread
Ok, I have my flame suit on. I am a newb to Hondas, but not to turning a wrench. I've been reading up as much as I can in the last few days trying to educate myself but I am going to ask this question anyways due to time constraints.
My ol lady has a '92 Integra with a spun rod and 3 other b18a1's that have some sort of issue. I have been having the worst luck trying to find a good shortblock for less than the price of my first born child. I did find a C1 longblock for a reasonable price that needs some work because it got wet, however that is easy money kinda stuff to deal with. What kind of drama, or is it even worth it to use that shortblock and mate it up with an a1 head? It needs to stay legit looking for the smog ***** and I can handle most issues that will arise with the proper guidance.
Thanks in advance
Old Feb 26, 2010 | 05:50 AM
ilikehonda's Avatar
Default Re: Another "will this stupid idea work?" thread
the a1 is non vtec correct? and you want to take a gsr motor and put the a1 head on it? my question is why? surely you can find a b18a1 long block or short block much cheaper than a gsr long block.
maybe you could throw in a b18b1?
Old Feb 26, 2010 | 06:27 AM
95 integra's Avatar
You can find a B18A1 for $100 or something. The oil feed on the B18C1 block for the vtec oil feed wont like that LS head, so I would avoid doing the reverse ls/vtec. Grab a good B18A/B or B20 for $750 or less and call it a day.
Old Feb 26, 2010 | 06:57 AM
mikesrex's Avatar
or just throw the GSR crank/rods/pistons in one of the B18A blocks if you already have the parts laying around.
Old Feb 26, 2010 | 07:34 AM
For some reason a good a1 block that needs nothing to run keeps eluding me. They all need to be decked, or the cylinders are not true, its been a pain in the butt for sure. In my observation any open deck honda once opened up is an immediate candidate for having the block decked, and assume that just because the cylinder walls still have cross hatching does not mean the bores are still true. Aluminum cylinder walls are great candidates for shifting around apparently. The two supposed good motors I have both still have visible cross hatching still on the walls but the mic states they are not true. If I put a motor in I want it to stay in there till I take it out in a million years. I like the idea of having a sleeved block just so the cylinders will have a better chance of staying true. I have been trying to find that $100 a1 block but they usually come from kids who abused them....
Old Feb 26, 2010 | 09:01 AM
88Hatchy's Avatar
You would be surprised at how inexpensive it is to rebuild the B18A engine.
Old Feb 26, 2010 | 09:25 AM
ilikehonda's Avatar
machine work is cheap. have it decked and honed then rebuild it
Old Feb 26, 2010 | 09:31 AM
negusjuda's Avatar
go to hmotors online and get a b20b long block and throw it in for about 600 bucks
Old Feb 26, 2010 | 09:01 PM
if all my motos needed were rings and bearings I would readily agree with that statement. i have two blocks that have visible cross hatching. In my mind that would have meant that all I needed was to clean,measure tolerances and assemble. In my case however I am looking at $600 or more to bore/build a shortblock. the bores do not have straight or circular walls. new rings cannot conform or seat to walls that are out of round, and rings will get a serious workout in the bore when its not straight. I do not want a smoker....
Old Feb 26, 2010 | 10:03 PM
88Hatchy's Avatar
$600 is cheap to rebuild an engine.
Old Feb 27, 2010 | 03:24 AM
negusjuda's Avatar
i still say hit up hmotors and grab a b20
Old Feb 27, 2010 | 10:15 PM
i have read that the motor you are referring to is not smog legal in California.
Old Feb 28, 2010 | 11:10 AM
98civdx's Avatar
Master Detailer
^^ no its not, you cant bar a jdm motor anymore in cali, besides just that, they wont let you have a truck engine in a car.
Old Feb 28, 2010 | 11:44 AM
negusjuda's Avatar
man that sux i would hate living in cali they sale ls motors too
Old Feb 28, 2010 | 11:56 AM
PyroProblem's Avatar
+1 for a low mileage b20 block...
Im sure you can have a little block stamp plate fashioned up that says b18a1 or whatever you need it to...
Not sure how tough the cali smog guys are, but im sure with a little creativity, you could trick em!
Old Feb 28, 2010 | 12:08 PM
mouab18c1's Avatar
Cali smog is pretty strict, dont live there but been there plenty of times to know. I think the OP's best luck is just buy a ls motor. They're cheap and easy to find
Old Feb 28, 2010 | 10:08 PM
i would fashion a blob of grease and a drive down a dirty dust road to hide whatever needs to be hidden, or just grind it smooth and stamp whatever I like in its place. that and find a smog guy who thinks it looks factory and lets it go through... still dont want to bother with the hassle if I get caught.
Old Mar 1, 2010 | 04:29 PM
APCXxstovetopxX's Avatar
do a b20 with a b18 valve cover they will never know the difference
Old Mar 1, 2010 | 06:36 PM
98civdx's Avatar
Master Detailer
^^ they arent that stupid! its not like they arent going to check the stamp.
Old Mar 2, 2010 | 12:55 AM
Meister vtec's Avatar
there is a reasonably cheap and easy way to restamp your b20.
what you need is fiberglass material,so wax,gelcoat,polyester,fiber sheets and some bondo.
clean the b18a stamp area,dry and apply wax and gelcoat(read the fiberglass kit instructions) and then apply your first sheet of fiberglass and brush it wet with some polyester then smear the air bubbles out,apply 3 more sheets the same way and wait to dry(atleast a few ours in sunlight or heat)
prime off the fiberglass and you will now have a reverse mould of your b18a stamp.
now shave the b20 stamp and apply some bondo and press the mould where the old stamp used to be and prime it off,repeat if not proper untill perfect.
then repaint the whole motor with aluminum paint and walla you now have a b20 with a b18 stamp and if you want it to look perfectly original switch valve covers
Old Mar 2, 2010 | 06:56 AM
I am a FNG about Honda motors, aside from more displacement, what is so great about a B20?
Old Mar 2, 2010 | 07:04 AM
88Hatchy's Avatar
The displacement is the only difference.
Old Mar 2, 2010 | 11:06 AM
there a compression difference of 0.4 between b20's and b18ab's. b20b's are 0.4 less and b20z's are 0.4 more with b20b at 8.8,b18ab at 9.2 and b20z at 9.6.
the jdm b20b with the p8r stamped on the head has vtec sized 33mm valves and 9.2 comp=best b20 if you ask me,especially if your gonna go boost
Old Mar 3, 2010 | 01:49 PM
and i have the b20 with p8r head which is why i reccomend it
freeagent
11
Jun 27, 2011 01:23 PM
Jumper101
14
Apr 26, 2011 11:09 PM
steinie88
Jun 26, 2010 12:40 AM
92EG8
12
Apr 30, 2008 04:30 PM
1.8Tities
Jul 17, 2002 09:56 AM
