Just bought an eg coupe w/ ls swap! Have some q's
Old Feb 25, 2010 | 08:54 PM
Yunsta's Avatar
Default Just bought an eg coupe w/ ls swap! Have some q's
Ok so my car doesn't have Ac can I use civic Ac parts or do I need to use dc parts? Also same question regarding t stat. Thx I checked though the site but did find anything quite like how I'm wording it.
Old Feb 25, 2010 | 09:04 PM
HooptyGSR's Avatar
Default Re: Just bought an eg coupe w/ ls swap! Have some q's
Well, speaking as a guy who has a car with no a/c and no p/s...
Anyway- I'd say the general rule of thumb is anything mounted to the engine get from the teggy and anything mounted to the car get from the civic. So mix and match from your local junk yard; mounting brackets, compressor, etc. from an LS motor and the "radiator" and misc mounting hardware from a civic.. The only tricky part would be the lines between the two. I'd assume that they're pretty much interchangeable but someone else may know better than me. Hope this helps!
Old Feb 25, 2010 | 09:08 PM
HooptyGSR's Avatar
Oh and the thermostat- I'm assuming you mean the one for the engine coolant. Grab one from an LS... Since it's part of the engine, rather than the car.
Old Feb 25, 2010 | 09:44 PM
civicsmoke's Avatar
For the A/C get everything from a civic including compressor, to mount it to the b18 you will need a delsol vtec A/C bracket, or a b20crv A/C bracket
Old Feb 25, 2010 | 10:06 PM
HooptyGSR's Avatar
i stand mildly corrected
Old Feb 26, 2010 | 12:10 AM
suwhoop's Avatar
who needs a/c when u got windows to roll down
Old Feb 26, 2010 | 04:24 AM
Matt93eg's Avatar
Finally correct information in this thread.
Old Feb 26, 2010 | 09:42 AM
Yunsta's Avatar
well I live in central fl so rolling down the window is not gonna be enough in a few months. As for the t stat do I need anything to accompany it in the replacement or is it take out old one and pop in the new one? Thx for all the info.
Old Feb 26, 2010 | 09:45 AM
Pauly D's Avatar
Old Feb 26, 2010 | 09:53 AM
civicsmoke's Avatar
you will need new gasket for the tstat.
Old Feb 26, 2010 | 01:02 PM
jcdimvic's Avatar
gasket usually comes with the thermostat, but other than that its a simple pull out and put in.
Old Feb 26, 2010 | 04:15 PM
Yunsta's Avatar
thx for all the info u guys know ur hondas. so just to be clear all i need is a teggie t stat and gasket.
Old Feb 26, 2010 | 04:36 PM
Pauly D's Avatar
rubber gasket normally comes already on the the tstat, it wouldnt hurt to add some rtv or whatever the water gasket crap they sell at advanced is...
Old Feb 26, 2010 | 05:40 PM
Matt93eg's Avatar
I've actually used several advance auto T-Stats and they never came with the gasket. Its been awhile since I have bought one so maybe now they come with them, if not maybe they sell them separately?
Shay Cothran
Nov 15, 2016 11:08 AM
mikehawk
Jul 11, 2009 06:18 PM
averyvm
May 27, 2008 10:10 AM
flyingduck04
Nov 15, 2005 05:51 AM
allmotorEG-SI
Apr 2, 2003 05:45 PM
