stuck in park
Old Feb 25, 2010 | 05:42 PM
FreshCD5's Avatar
Default stuck in park
my car got stuck in park today. i press the break still wont shift. so what i had to do is cut the car off and pull the e-brakes up and put and car in N and start. then i out in in drive. but when i put back in park get stuck again. i cut the car off for about 10 minutes started the car in got out of park with no problem. what can this be
Old Feb 25, 2010 | 06:07 PM
slomofo's Avatar
GDD Member
Default Re: stuck in park
Neutral Safety Switch
OR
Shifter cable adjustment.
Old Feb 25, 2010 | 07:49 PM
FreshCD5's Avatar
OR
its an automatic to let you know
Old Feb 25, 2010 | 07:52 PM
lobudgetr's Avatar
It sounds like that stupid switch that sits on the brake pedal may be going bad.
Old Feb 25, 2010 | 08:00 PM
matt96ex's Avatar
its probably the shift interlock solenoid. do you hear a click noise when you press on the brake pedal?
Old Feb 25, 2010 | 08:02 PM
redbull-1's Avatar
Yes, probably the brake light switch. The plunger on the switch may have deteriorated/broken off.
See this link for this guy's cheap fix:
http://ldsdates.com/blog2/2007/09/18...-light-switch/
You can always replace it too.
Old Feb 25, 2010 | 08:09 PM
redbull-1's Avatar
See this:
Old Feb 25, 2010 | 08:25 PM
FreshCD5's Avatar
i was not getting it i had to cut my car off put it in N the start the car cut it back off for like 10min then start back came out of park with no problem started to get the interlock
Old Feb 25, 2010 | 08:26 PM
FreshCD5's Avatar
Originally Posted by redbull-1
See this:
thats what am going to do
Old Feb 25, 2010 | 11:55 PM
Dannyvho's Avatar
On the shift lever console you may find a little lid: if you remove it you can use a pin to manually override the blocking of the shift lever in P. This override procedure is also described in the owner's manual.
Mrbractjones
Apr 26, 2014 02:40 AM
timrichter9
Feb 25, 2010 04:11 PM
boblikesrock
Nov 29, 2006 06:55 PM
NYCsnowman
Jan 24, 2006 01:13 PM
yellowdcn
Feb 28, 2005 01:06 PM
