what do you think ??? 1991 integra LS
Old Feb 25, 2010 | 03:30 PM
lancerkid06's Avatar
Default what do you think ??? 1991 integra LS (pics added)
aight i sold my 95 LS and decided to just get something for a DD and picked up a burgundy 2dr 91 LS .. i paid $1500 for the car and wanted to get everyones opinions.... car is stock with 188k miles and automatic but thats ok for the time being. within the last 4 years it has had all this replaced. windshield, exhaust, timing belt, water pump, battery, front/rear brakes, alternator, new tires, spark plugs and i think that was it. the only thing wrong with the car is couple small dings/dents nothing bad, little small rust spot on bottom of driver door, rip on drivers seat, and the valve cover gasket leaked.
but anyways after driving the car for like 150miles it started to sputter and i noticed it had oil in the 2nd spark plug.. so i went ahead and replaced the valve cover gasket, spark plug seals, and put new spark plugs in. so do you think i should be good to go now with no problems? im letting the sealant dry over night then gonna go for a test drive tomorrow. also the car would drip oil out of the exhaust pipping about mid way under the car where it was welded at in one spot. mechainc said it might be because of the oil that was leaking into the spark plug? idk.
but let me know if you think that was a good deal. and if you think that will solve the leaking oil problem and what you might think would cause the oil to drip out the exhaust pipping after driving the car.
Old Feb 25, 2010 | 03:34 PM
Default Re: what do you think ??? 1991 integra LS
also forgot to mention the antenna wont go down. you can hear the motor working but it wont go down. but if you push on it when someone turns the key it will go down then turn the key on and it will raise up.. so is it just disconnected or how would i go about fixing that?
Old Feb 25, 2010 | 04:48 PM
Tarmac Junkie's Avatar
Well if a new valve cover gasket fixed the oil leak, then it was a good buy.
Old Feb 25, 2010 | 07:14 PM
mspeed's Avatar
New User
Power antennas die frequently and have to be replaced. Mine is dead and I'm probably going to replace it with a fixed mast stubby.
Old Feb 26, 2010 | 01:39 PM
i dont think the antenna is dead. i can hear the motor come on when i turn the key and when i turn the key off ... and if i push down on it while someone turns the key the antenna will go down. and then all i got to do is turn the key back on and it will raise up by its self ... but got pics of the car up now so let me know what you guys think if it was a good deal or not
still havent washed to car due to weather
Old Feb 27, 2010 | 04:10 PM
today i cleared out my tail lights ... so now there white over red .. the 50/50 style instead of being that foggy pink color ... and tinted my fog lights yellow ... i think it makes the car look alot better. will have pics up when i get them uploaded .. also got to wash the car today. so its all clean now
Old Feb 28, 2010 | 09:47 AM
pics of the fog lights and the cleared out tail lights.. couldnt find my camera so i had to use my cell phone =(
Old Feb 28, 2010 | 10:02 AM
bank2me's Avatar
Your car looks very simialar to mine. I think it was a good deal. Looks like a clean whip. I think you did alright.
Old Feb 28, 2010 | 10:40 AM
Alex M.'s Avatar
nOOb question, how did you clear out the rear tails? Car looks good BTW!
Old Feb 28, 2010 | 12:36 PM
take the tail lights out and the bulbs and wires off the tail light. then pour degreaser in the clear part and shake it around for like 30sec to 1min then dump it out and spray it out with water make sure u get all the degreaser out and dry with blow dryer until dry then put it all back together
Old Feb 28, 2010 | 12:58 PM
da9bigboi's Avatar
looks clean though, except for the seats
Old Feb 28, 2010 | 01:28 PM
josh-roy's Avatar
Its a frequent isue that the plastic gears that allow the actual mast to go up or down get worn and won't allow it to move. You can buy a replacement one on Ebay. I got one, my motor was fine but the gears as mentioned were worn.
Old Mar 1, 2010 | 05:44 PM
oh aight, well ill check into that .. but does anyone have any suggestions for some minor mods for the time being ... some that are cheap
Old Mar 1, 2010 | 09:47 PM
OrangeTeggy's Avatar
why the down grade?
Old Mar 1, 2010 | 11:14 PM
got laid off my job and had bills to pay and i owe back on my taxes =( so i had to sale the DC and i didnt want anything else but a honda/acura ... so i scooped up this clean DA for $1500 ... but eventually it wont be a downgrade once i get another job and some more funds to work on the car ... i plan to swap it and convert it to manual in the future .. but since this body is in almost perfect condition i can just get all my exterior parts and fix all the small dings it had and paint everythign at once keep it all nice and fresh looking ... lol
i do miss my DC though. but once this is a manual i think i'll feel more comfortable in it until then its w/e just a car. kinda boring driving without having to shift gears =(
Old Mar 2, 2010 | 12:25 AM
Honda_ThuGZ's Avatar
clean da i just got done doing my auto to stick on my DA
**** was a bitch since i did everything myself and had to buy extra parts
Old Mar 2, 2010 | 09:56 AM
team jdmboyz's Avatar
New User
clean da body
Old Mar 2, 2010 | 03:38 PM
thanks. i dont know where to start at with it. i was thinking i should order all my lighting stuff first (amber corners, amber bumper lights, 8-10k HID's, and amber side markers) .. then work on the performance stuff, wheels, and suspension .....
what is a good brand that isnt to expensive for a nice size drop .. like is D2 any good or are skunk 2 better. i was on ebay and seen i can get either set of those for like $160
Old Mar 2, 2010 | 03:47 PM
eatsleephonda90's Avatar
good deal but i couldnt handle it being auto lol
Old Mar 2, 2010 | 07:35 PM
just wondering what is the exact color of my car is it torino red? and didnt that color only come on the 90-91 LS models?
also does anyone have a list of everything that i will need to do a 5speed swap in my car? and what do u think the average cost to do a complete swap with all the parts cost? thanks
Old Mar 3, 2010 | 06:31 PM
B series Manual trans($300 depends where you live)
clutc/hpressure plate/throwout bearing/pilot bearing(FULL CLUTCH kit)($150 OE exedy at Streetsideauto)
Flywheel-(used one plus resurface $25)
flywheel bolts(freind gave them to me)
PP bolts($13 for ARP at summit)
Manual intermediate shaft(friend gave it to me)
Shift linkage n bitch pin($30 on CL)
ES shifter bushing kit($15 at summit)
shifter n ****(came with shift linkage)
shiftboot(5 finger discount at local JY)
5speed pedals($45 at JY)
5speed cluster or just bezel but its really up to you
clutch cable(Friend gave it to me)
Manual intake mani(im still using my auto)
I highly recommend the innovated auto to manual mount($155 at innovated)
MT Pr4 ecu year specific(im running a 91 in a 90 no CEL ...yet)
2 or 3 quarts of honda MTF(or oil of your choice)
IDK if im missing anything but it cost me roughly $800 just parts did all labor myself
check these links out read everything
https://honda-tech.com/forums/acura-integra-6/1990-1993-integra-automatic-manual-transmission-conversion-2304301/
http://www.g2ic.com/forums/showthrea...ick+conversion
http://hondaswap.com/swap-articles/a...version-27054/
Old Mar 5, 2010 | 09:31 AM
dak20a2's Avatar
New User
stupid clean da have fun with it
Old Mar 5, 2010 | 01:48 PM
how hard is it to do all the labor yourself? and do i have to pull the motor in order to do this? i really miss having 5-speed .. i might just look for a cheap DA tge with a blown motor or somethign thats already manual and just take everything from that car to do it
Old Mar 5, 2010 | 04:23 PM
You dont have to pull the motor just drop the crapauto out n put flywheel/clutch/PP in put tranny back up put in the 5speed pedal assembly make a hole for the clutch cable put on the shift linkage do a lil wiring and your good to go
it took me 2 weeks since i ended up ordering the mount n it got back ordered so most of the time was waitn for parts
but i did all the work my self i wanna say it took me roughly 18 hours(all together) taking my sweet *** time i also put in a new dash in and a couple other accesories
Old Mar 7, 2010 | 01:35 PM
aight .. i found a shell for cheap just waiting for the guy to email me some pics and let me know if it is a 5speed and if it still has the tranny in it or not .... but i will have some more updated pics of my car in the next couple days
