How to tell if iab is working
Old Feb 25, 2010 | 12:50 PM
jdmstyleEJ6's Avatar
Default How to tell if iab is working
okay guys i have searched high and low for this but havent found
that much info so i was jus wondering if any one know how to tell if my iab is working now i have a 96 civic dx w/ jdm gsr and jdm ecu also i have no check engine light thank yall in advance
Old Feb 25, 2010 | 01:21 PM
Default Re: How to tell if iab is working
bump
Old Feb 25, 2010 | 01:45 PM
Vindicator9000's Avatar
318 Curves, 11 miles
locate the IAB vacuum diaphragm on the driver's side of the intake manifold. You should be able to open and close them with your fingers to make sure it's moving correctly.
Start the car and warm it up to operating temperature. Have someone blip the throttle past 6K rpms a few times. You should see the mechanism coming out of the bottom of the diaphragm open and close as it passes about 5600rpm.
Old Feb 25, 2010 | 01:51 PM
where at on the iab is the diagram located
Old Feb 25, 2010 | 02:37 PM
bump
Old Feb 25, 2010 | 02:53 PM
bump i realy need to know were the diagram is
Old Feb 25, 2010 | 03:01 PM
Anon51's Avatar
on the intake manifold, driver side of it.
Old Feb 25, 2010 | 03:26 PM
it's a big round thing on the driver's side of the intake manifold. It should have a vacuum hose coming out the top of it.
losopontes
Oct 14, 2008 01:03 PM
818SpoonITR
Feb 23, 2008 05:28 PM
Spence
Northwest (Sales)
12
Oct 26, 2006 03:43 PM
wanttorace
Jul 10, 2003 09:30 AM
