Installing spoon calipers
Old Feb 25, 2010 | 04:59 AM
RGoose18's Avatar
Default Installing spoon calipers
Are there any extra parts, steps or precautions needed when installing these calipers?? Looking into getting a pair and have yet to see an install write up
Pics for good measure
Old Feb 25, 2010 | 06:29 AM
whatcivic's Avatar
Default Re: Installing spoon calipers
they come with instructions. pretty straightforward except that you have to cut/trim your dustshields.
Old Feb 25, 2010 | 06:57 AM
get RIGHT's Avatar
same as what you have in the pic I believe.
http://www.spoon.jp/dl/45020-EK9-G00_EG.pdf
Old Feb 25, 2010 | 07:00 AM
shattachris's Avatar
how much a set of those cost
Old Feb 25, 2010 | 07:52 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
You can contact Opak Racing or GT Motoring for pricing. For used ones, prices vary a lot depending on condition.
GTM crewed for Opak during the 25hr T-Hill race several years ago:
www.gtmotoring.com
Old Feb 25, 2010 | 03:48 PM
Mashimaro's Avatar
Install is pretty straight forward. there's a certain way the washer is supposed to be though depending what year brakes you have, but your instruction manual will tell you that in the pictures.
also, use a tq wrench on the mounting bolts as they're made of aluminum i believe.
other than that, i find that bleeding the inside first, then outside for each caliper gets more air out for some reason.
pads are your typical ITR pad. but you'll have to shave the back to be flat.
good luck!
Old Feb 25, 2010 | 05:17 PM
Seedc2's Avatar
does anyone know how big those washers are?
Is it okay to remove the dust shield completely?
Old Feb 25, 2010 | 05:34 PM
Mashimaro's Avatar
i've taken the dust shield off mine completely. no issues.
washers are about the size of a nickel if i recall. i'm sure reusing OEM bolts are ok too as long as you antiseize.
Old Feb 25, 2010 | 06:17 PM
Loud-N-Clear's Avatar
I bought a set of Spoon twin blocks used and I am about to install them on my 2000 ITR. I didn't receive the bolts or washers with them, or any other parts, just the calipers themselves. Which bolts and washers do I have to purchase to do the install properly? Also, are there any other parts included wth the calipers new that I am missing?
Old Feb 25, 2010 | 06:20 PM
Mashimaro's Avatar
i'm sure you can reuse your OEM bolts (the ones that bolt the caliper onto knuckle), just make sure you use antiseize.
no other parts really other than pads and the washers for your brakeline going in.
Old Feb 25, 2010 | 06:53 PM
Wai's Avatar
Wai
The bolts that come with the Spoon calipers are *longer* than OEM. I'm not sure by how much, but if Spoon bothered to provide the longer bolts, then I think they are necessary.
Old Feb 25, 2010 | 09:28 PM
cxSHOE's Avatar
correct. spoon bolts are longer.
i will get exact mesurements of bolts and washers tomorrow if someone doesnt before me.
spoon on left with washer, oem on right ajr in canada should be able to get you the bolts. opak could careless unfortunately. lol
Fly ef8
Dec 14, 2012 10:25 AM
Kid1320
91
May 11, 2005 06:00 PM
carblegal
Jun 1, 2003 08:02 PM
Jason
Oct 22, 2001 10:31 PM
