Fitting Slicks on 91 CRX SI
Old Feb 24, 2010 | 07:43 PM
catfishracer4748's Avatar
Default Fitting Slicks on 91 CRX SI
Hello, I have a 91 crx si and want to run 24.5 x 8.5 x 13 m&h slicks. I ordered some 13x8" wheels with a 5 inch backspace. Well I just remeasured and it appears they may rub on the upper balljoint nut area. Has anyone mounted similar wheels slicks on there crx? Should I try to change my order to 4" backspace?
Old Feb 24, 2010 | 07:54 PM
88Hatchy's Avatar
Default Re: Fitting Slicks on 91 CRX SI
What brand of wheels did you get?
Old Feb 24, 2010 | 08:03 PM
Diamond Racing http://www.diamondracingwheels.com/
Old Feb 25, 2010 | 05:18 AM
k
Old Feb 25, 2010 | 05:37 AM
dpetro1's Avatar
those should have slightly (7mm) more inner clearance than lensos so i think you will be just fine
Old Feb 25, 2010 | 07:54 AM
But will that affect how close the tire sits to the knuckle area. Like I said its the upper balljoint castlenut area where the upper ball joint attaches to the knuckle that looks like it may be an issue with tire clearnce.
Old Feb 25, 2010 | 08:12 AM
dpetro1's Avatar
sorry if i was unclear. what i was getting at is that i see plenty of crx's on lensos, which have a higher backspace and sit closer to the inner suspension (knuckle & uca). your wheels should have more clearance to those components
Old Feb 25, 2010 | 08:34 AM
I know the wheels will clear just fine. It's the tires I'm concerned with. But I will assume your saying since the wheels will have more clearance, so should the tires. BUT....
7mm is about a 1/4 inch. That extra amount on the lensos is the thickness of the rim lip. Yes the Lenso wheels sit back farther because they have about 1/4 in. thicker bead lip than my steel wheels, but the tire still beads up at the 5' backspace so I dont think it will make a difference on TIRE clearance. correct me if im wrong.
I hope I dont need wheel spacers. They are just kinda cheezy. do a lot of guys run them?
Old Feb 25, 2010 | 09:49 AM
dpetro1's Avatar
yeah i guess 1/4" isnt much of a difference but even still i think you will be ok. dont be afraid of spacers, they do their job and then can get taken off when you leave the track. i run 5mm spacers on my drag wheels for brake caliper clearance (15" 5-lug though)
Old Feb 25, 2010 | 11:27 AM
1.888'rex's Avatar
me and all the crxs in my class run lenzos and have to clearance issues
we have tires sizes from 22's to 24.5 by 9s have clear you should not have a problem if a slight clearance is needed a small wheel spacer is fine will not hurt anything
when using beadlockers on the lenzo a spacer is need in the cases i have seen and they have not had problems
youll be fine
Old Feb 25, 2010 | 12:45 PM
most_hated_crx's Avatar
ive used lenzos and now spinwerks on 24.5x9x13
no clearance problems at all
Old Feb 25, 2010 | 03:32 PM
youll be fine
Good to hear. I'll know within a week if they will clear or not. At most a 1/4" spacer is prolly all I will need. Should be fine it seems.
Just curious why when using beadlocks on the lenzo wheels the spacer is needed?
Old Feb 25, 2010 | 03:34 PM
what backspace?
Old Feb 26, 2010 | 05:07 AM
dpetro1's Avatar
i know lensos are all 13 x 7.5 +25 offset (5.25" backspace)
Old Feb 26, 2010 | 11:47 AM
1.888'rex's Avatar
with the beadlock you run the new bolt on lip and bolts stick out father which make clearance tighter only a small one is need that i have seen
Old Feb 26, 2010 | 02:38 PM
Gotcha!
Old Mar 9, 2010 | 04:36 PM
I hate it when nobody updates a thread with the final outcome. So I will finish up.
The 13 inch diamond racing wheel w/ 5 inch backspace fit perfect. The 24.5x8.5x13 fit great with plenty of room to spare. I could probably go another size up in the future if needed. So it all worked out good. As far as fender clearance ect. it should be fine after I adjust my coilovers.
There, I feel better now.
Old Mar 9, 2010 | 05:38 PM
theidealone's Avatar
Pics.
Old Mar 9, 2010 | 05:45 PM
XXXRacing's Avatar
I used to run welds with a 15mm spacer..forgot what offset..either 4 or 5"
Old Mar 9, 2010 | 07:11 PM
Originally Posted by theidealone
Pics.
where?
Old Mar 9, 2010 | 09:48 PM
Post some. Would like to see how far the slicks stick out with that offset and steelies.
Old Mar 10, 2010 | 05:35 PM
Sorry, I didn't understand your original one worded question without the question mark.
It is up on jackstands right now as I'm working on other areas of the car. I will possibly post some pictures when I'm finished.
Old Mar 10, 2010 | 09:47 PM
It wasnt a question. More of a request or demand, which doesnt require a question mark.
No biggie, I have a few friends with similar wheels, just wanted to see what your backspacing looked like.
NickCartuhhh
Dec 30, 2015 05:39 AM
HondaHeddie
Nov 17, 2005 10:35 PM
ernald711
Jul 29, 2005 04:41 PM
sonicrex
Jun 24, 2004 02:49 PM
dafuture197
Jul 21, 2002 07:51 AM
