brake problem on 92 accord
my sister has a 92 accord when we come to a stop the car brakes good but after it comes to a complete stop the brake pedal goes in. anyone know what can cause that to happen?
Fluid is leaking somewhere then, so check the brake hoses on the calipers, the rear wheel cylinders if it has drum brakes out back, and also look for wet spots near the brake master cylinder.
The brake pedal goes to the floor because there's air in the system and you need to bleed it, but you need to fix the leak before you do that.
UnrealSpeed
May 17, 2003 01:45 PM
