stock d15 not starting
Old Feb 24, 2010 | 03:48 PM
GreenGoblinEF's Avatar
Default stock d15 not starting
we originally had a no spark problem but we replaced the distributor and now we have spark but we still cant get it to start. what would be the easiest way reset to tdc and how can i tell if it was just the spark that was the problem? any suggestions or thoughts would be greatly appreciated
Old Feb 24, 2010 | 03:49 PM
ELOYD's Avatar
Default Re: stock d15 not starting
u need to set the timing
Old Feb 24, 2010 | 03:50 PM
how would i go about doing that?
Old Feb 24, 2010 | 03:53 PM
pi Ka chuuu's Avatar
Be a little more specific is it a crank no start? or a no crank no start? Think of all the things you need for a car to start, You already checked spark and stated you have spark. you also need fuel, turn the ignition on to see if you hear the fuel pump going. you also need air. Maybe you have a clogged cat? Im just trying to help you further diagnose the issue.
Old Feb 24, 2010 | 03:54 PM
ELOYD's Avatar
i cant explain will take too long. wat year is the car
Old Feb 24, 2010 | 03:55 PM
ELOYD's Avatar
yeah u right
Old Feb 24, 2010 | 03:56 PM
ELOYD's Avatar
take the headers out then try it
Old Feb 24, 2010 | 03:57 PM
the fuel pump turns on. it cranks it just doesnt start
its a 1991 honda civic hatchback
Old Feb 24, 2010 | 03:58 PM
ELOYD's Avatar
i cant wait to put my rear lower control arm, exhaust, rear suspension, motor mount
Old Feb 24, 2010 | 03:59 PM
ELOYD's Avatar
crank it with spark plug out just becareful with spark plug cable. see if the engine is flooded
Old Feb 24, 2010 | 04:00 PM
ELOYD's Avatar
let me search honda isis web page to see any bulletin brb
Old Feb 24, 2010 | 04:01 PM
98_DX's Avatar
yeah definately check if its flooded. it happened to me before
Old Feb 24, 2010 | 04:09 PM
ELOYD's Avatar
does it have spark
Old Feb 24, 2010 | 04:14 PM
ELOYD's Avatar
too moch stuff on the web site
Old Feb 27, 2010 | 11:16 AM
it has spark im getting the timing reset today or tomorrow to see if thats the problem
Old Feb 27, 2010 | 07:28 PM
bumm03's Avatar
timing or fuel...
Old Feb 27, 2010 | 08:52 PM
ItsMikeBABY's Avatar
idk.. but is your relay commin on? maybe its the relay or your fuse box under your hood cause it happen to my firends EF9 and he's ecu wasnt throwing codes but was cranking and he replace his distributor before he had this problem because his car was cranking to but didnt want to turn on, so he replaced the relay and the whole fuse box under the hood next to the battery...look at the ecu for codes...
Old Feb 28, 2010 | 03:00 PM
projekt90ef's Avatar
yea check the relay for cracked solder before you pay to get the timing reset. could be a free fix with a soldering iron...start with the cheapest possible solution first...always
yOnKiNaToR
Mar 26, 2009 05:19 PM
mygfs92lx
Jul 19, 2006 06:33 PM
same ol' civic
Jun 5, 2005 07:29 AM
bonestock92si
38
Aug 30, 2004 10:02 PM
b18c1eg2
Aug 21, 2004 12:28 AM
