1991 honda accord help
Old Feb 24, 2010 | 03:45 PM
usdmm's Avatar
Default 1991 honda accord help
so i got a 1991 honda accord lx stick and i tried to smog it but it failed smog. it has the check engine light on and one of my hoses has a small hole in it so its leaking out coolant. the ecu number is 37820-pt3-a03 and the engine is a single cam. how can i get somecodes to know what is wrong with the car, im going to replace the hose. if someone can help me than that would be great
thanks!
Old Feb 24, 2010 | 03:54 PM
slomofo's Avatar
GDD Member
Default Re: 1991 honda accord help
Stick a paper clip in that plug with the key on and engine off, then watch the magic unfold on your dashboard.
Your check engine light will start blinking, count the blinks.
1 fast blink, pause, 2 fast blinks = Code 12
1 fast blink, pause, 3 fast blinks = Code 13
And so on, and so forth.
Post your VIR and I can tell you the most likely causes to your problem. The VIR is the white paper the emissions guy should've given to you. It'll display items such as RPM, HC PPM, CO %, and NOx PPM.
Old Feb 24, 2010 | 03:57 PM
slomofo's Avatar
GDD Member
Oh yeah, forgot the codes, here they are...
Old Mar 4, 2010 | 02:50 PM
usdmm's Avatar
i did the jumper harness and the check engine light blinks and stays on then blinks and stays on. its the same speed everytime it blinks what does this mean?
Old Mar 4, 2010 | 07:48 PM
usdmm's Avatar
ok so i replaced to o2 sensor and it shots a new code, code 15 what is that how how can i fix it?
the car runs fine, only problem is check engine light.
Old Apr 26, 2011 | 11:25 PM
RALPH626's Avatar
Icon2 Re: 1991 honda accord help
sooo my engine light blinked 7 times.? anyone wanna help.
and on a side note. i crashed a while back and it hasnt ran the same. i fixed the radiator. n the hood. and bumber. ever since that my rpms act wierd when i start hitting 40 on the street, and it bogs and pops and it seems like my engine has a restriction and i have to punch it so it doesnt keep popping.
Old Apr 26, 2011 | 11:26 PM
RALPH626's Avatar
ive also taken it to a mechanic and he says he has never seen anyhing like this.
Ankit Poonia
Feb 21, 2015 05:01 AM
Ali Hussain Ali
Apr 8, 2014 07:48 PM
Hondalina
Dec 13, 2010 02:39 PM
blindman
Apr 11, 2006 12:39 PM
