Ecu question, possibly a problem
Old Feb 24, 2010 | 01:34 PM
Staypuff578's Avatar
Default Ecu question, possibly a problem
A quick intro on my car, 88 hf, y8 swapped, running obd1 off a p28.
The issue: my p28 doesn't show a check engine light when i turn the key before i start the car. There is no signs of a CEL existing with this ecu. I plugged in 3 different p06 ecu's and one from my buddys crx and they all show the CEL before the car starts and when running (tranny sensor due to ecu being auto). It's only with this p28 that it shows not a single sign of a CEL at all. The main answers i have been getting are: ecu is bad and it may be chipped. The car runs perfect not a single thing wrong with it (that i know of, hell my vtec may not engage and i wouldn't know), so that tells me the ECU isn't bad. Now onto the it may be chipped; how would i be able to figure this out? Thanks in advance for any help
Old Feb 24, 2010 | 03:52 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Ecu question, possibly a problem
Pull off the cover and take a picture of the inside of the ECU. Post it up here and we will tell you if it is chipped or not.
Old Feb 24, 2010 | 04:48 PM
Old Feb 24, 2010 | 06:43 PM
anymore thoughts?
Old Feb 24, 2010 | 06:47 PM
D16SiHatch's Avatar
nope, not chipped.
unfortunately i can't tell you why the cel isn't coming on. not somethin i've ran into before
Old Feb 24, 2010 | 06:51 PM
Creator's Avatar
It doesn't look like it's chipped. If it was I believe that there would be a chip where it says "27256"
bottom right corner in first pic
Old Feb 24, 2010 | 07:43 PM
I figured it wasnt chipped. Hmmm maybe theres just something wrong with it. I honestly dont think my vtec engages because my motor falls face first in the 4k+ rpm range, unless my timing is retarded to **** or perhaps its being choked going from the y8 manofold/downpipe to the stock hf (1.5 inch i think) piping
Old Feb 24, 2010 | 07:46 PM
D16SiHatch's Avatar
hmmm. well that could definitely restrict it a good bit.
run a test wire to the vtec solenoid wire at the ecu and see if a multimeter or test light will read +12v when you're in the vtec rpm range.
Old Feb 24, 2010 | 08:05 PM
I will give that a shot tomorrow, if it's not engaging then that might be my ballsless motor issue, if it is engaging im gonna time it and run open header to see if it is indeed a restriction problem
Old Feb 25, 2010 | 04:23 PM
Creator's Avatar
I don't think you'll see much of a restriction issue. If vtec wasn't working it shouldn't really fall on it's face. In my experience exhaust noise just kind of levels out and so does power/acceleration.
DaddyKin
14
Jul 12, 2011 01:52 PM
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
Dc4iNtEgRa
Apr 1, 2010 07:59 AM
drshottest718
May 22, 2006 04:31 PM
spoonhatchblack
Nov 4, 2004 10:12 AM
