b16 thermostat question
Old Feb 24, 2010 | 11:53 AM
ninty1civic's Avatar
Default b16 thermostat question
I was wondering what kind of usdm car i can buy a thermostat from, for my buddys obdo b16? looking to buy a thermostat at a parts store like advanced auto, napa, salvo, etc.. But they dont carry "jdm b16 parts" lol what will work?
Old Feb 24, 2010 | 11:55 AM
Default Re: b16 thermostat question
what about the thermo/fan switch too?
Old Feb 24, 2010 | 02:02 PM
lunalink's Avatar
i'm sure the thermostat off of the '00 si would work.
Old Feb 24, 2010 | 02:04 PM
D16SiHatch's Avatar
you can get both parts from a 99-00 Civic Si with the b16a2
Old Feb 24, 2010 | 02:11 PM
lunalink's Avatar
yup!
Old Feb 24, 2010 | 02:29 PM
thanks you both
Old Feb 24, 2010 | 02:37 PM
lunalink's Avatar
np
Old Feb 24, 2010 | 04:26 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You will need to get it from a 90' Acura Integra (B18A1). The OBD-0 fan switch is different than the OBD-1 and OBD-2 counterparts.
Here is a good rule of thumb to go by. You should NEVER jump two OBD's when trying to get parts (especially electrical related items).
If you need motor related electrical parts or distributor parts use a 90' Integra.
If you need mechanical parts (like internal parts or gaskets) use a 95' Del Sol VTEC (B16A3).
This is all obvious and everyone should learn to know this and love it.
Old Feb 24, 2010 | 04:27 PM
DO IT ON ALL FOURS
Well actually, I always use a 91' Integra...
Old Feb 24, 2010 | 04:39 PM
well ive got 2 answers.. 99-00 si thermo switch which has one 2 wire connector.. and a 91 integra ls thermo switch which has 2 small single wire connectors.. the car is a 91 crx si which uses 2 small single wire connectors, but the jdm obdo b16 motor in the car has one 2 wire connector.. My question is, will and obd1 or obd2 switch work fine if we change over the connector, or will an 91 obd0 d series switch work? basically im wondering if the obd0 d series switch is going to screw in to the b16..
Old Feb 24, 2010 | 04:43 PM
because it doesnt look like it will..
Old Feb 25, 2010 | 08:01 PM
bump..
StrikerX
Aug 4, 2004 06:58 PM
mycvc8u2
Jul 30, 2002 04:48 PM
