cluster lights and tach not working!!!
Old Feb 24, 2010 | 10:48 AM
vtechjunkie's Avatar
Default cluster lights and tach not working!!!
So I had my car(99si) tuned the other day and upon starting the car I noticed that the tach was not working. The tuner said that it was something in the cluster, because the computer was reading the rpm just fine. It's a stock cluster. So my first question is:
1. Is there a way to fix the tach? Maybe it is a loose wire in the cluster itself that can be re-connected?
And secondly, the cluster lights do not work when the lights are on. The question here is:
2. Are these two problems associated? Could it be the bulbs are just out and need replacing? or should I figure out the tach problem first; Just to see if I need a new cluster anyway?
Any help would be appreciated. Thanks in advance.
Old Feb 24, 2010 | 10:52 AM
andoxviii's Avatar
Default Re: cluster lights and tach not working!!!
Well your first step should always be to check fuses in the fusebox under the steering wheel.
Old Feb 24, 2010 | 08:16 PM
All the fuses are good! I did figure out that the running lights were because of the adjustment **** not being plugged in. But haven't figured out why the tach isn't working. I have another one, I just want to figure this one out so that I can sell the other one.
V.MoMO
Sep 12, 2010 08:44 AM
SLOENUF
Apr 30, 2010 09:30 PM
gotgohan
Jul 12, 2009 11:35 AM
SONSON_EJ8
Oct 29, 2007 09:13 AM
