quick b20 question.
Old Feb 24, 2010 | 08:57 AM
upgrayedd's Avatar
Default quick b20 question.
will a valve from a 91 LS head fit in my b20z2 head? the exhaust valve has a hole in my b20 and i have an ls head in my garage. thanks in advance
Old Feb 24, 2010 | 09:08 AM
akurtzer57's Avatar
Default Re: quick b20 question.
Im pretty sure they are the same. You can get a brand new valve for $15-$25 I would replace them all if you have a b20 head Depending on your funds. I know my b20z when I got it had the sunken valve problem. I just put a older ls head on.
Old Feb 24, 2010 | 09:23 AM
DumaDA's Avatar
what is the "sunken valve problem" ?
Old Feb 24, 2010 | 09:24 AM
upgrayedd's Avatar
I dont rly wanna put an ls head on it, i mean, i wanna keep the b20 head idk why, but how positive are you that the valves are the same?
Old Feb 24, 2010 | 09:58 AM
tsdneil's Avatar
im almost certain that the b20 head and the ls head are exactly the same. someone correct me if i am wrong.
Old Feb 24, 2010 | 10:12 AM
DrGrEeNtHuMb's Avatar
check the stamp on the head. if its p75 then yes, same head cast as an ls, if its pr8 then no, they have bigger valves
Old Feb 24, 2010 | 10:55 AM
upgrayedd's Avatar
p75 head.
Old Feb 24, 2010 | 11:05 AM
DumaDA's Avatar
interchangeable valves then
Old Feb 24, 2010 | 11:42 AM
upgrayedd's Avatar
thanks man
Old Feb 24, 2010 | 11:54 AM
DumaDA's Avatar
do you have a b20b or a b20z? If you have a b20b putting the ls head on their would give you more power haha
Old Feb 24, 2010 | 01:29 PM
upgrayedd's Avatar
my engine is B20Z2. so thats why i thought LSA valves wouldnt work.
Old Feb 24, 2010 | 01:45 PM
akurtzer57's Avatar
b20z2 all the way! Now have built head with crower 402 arp studs. Block guard top mount. Will be fun this spring.
Old Feb 24, 2010 | 01:50 PM
DumaDA's Avatar
what transmission are you running?
Old Feb 24, 2010 | 04:40 PM
upgrayedd's Avatar
dont have one yet
Old Feb 24, 2010 | 04:44 PM
EnviedByMany's Avatar
I got a rebuilt B20b head for sale.
Old Feb 24, 2010 | 11:06 PM
Fallout's Avatar
I had a 99 EX auto V and now I have a 99 EX 5 speed. I've never had a problem with my current eventho i've only had it a short time. My previous has gone 90k miles (my ex still drives it) without a valve adjustment.
That being said, a lot of people on the CRV-OC say that the V (and consequently the B20 motors) should have a valve adjustment much more often than the listed interval in the manual because the valves "tighten" on the B20 head and receed. I can't substantiate the claims with evidence but others seem to have had this problem semi commonly, maybe i'm just lucky.
93-eghatch
Feb 6, 2021 01:26 PM
Davey12678
Dec 6, 2011 12:03 AM
Mr Itr
Mar 5, 2009 02:02 PM
jdm92teg
Feb 24, 2005 12:23 PM
m3ster
Jan 31, 2004 01:12 PM
