97 Accord: Spark plug in Cyl 2 wont come out
Old Feb 24, 2010 | 08:25 AM
smoov_w4gon's Avatar
Icon3 97 Accord: Spark plug in Cyl 2 wont come out
Yesterday me and my friend were going to check the compression on my 97 Accord Wagon. I could not take out the spark plug in cylinder 2. It wouldnt budge at all! I didnt want to risk breaking anything. What are my options? I thought about doing the G23 swap, or maybe just swapping a F23 in because my F22B1 is getting close to 200k. My buddy told me i may need a new head or need to get the threads redone. Can i get your opinions, experiences with this problem or suggestions? Thanks.
Old Feb 24, 2010 | 08:32 AM
redbull-1's Avatar
Default Re: 97 Accord: Spark plug in Cyl 2 wont come out
What some people have done, use penetrating oil and let it soak for at least a couple of hours and try to remove very carefully. May have to try very slight turning of ratchet both ways first.
Note: Do not use WD-40, as that is not a penetrating oil.
Old Feb 24, 2010 | 09:18 AM
alright ill try this first. i hope it works. thanks for the suggestion.
Old Feb 24, 2010 | 09:39 AM
dagle's Avatar
Penetrating oil first, then high quality socket such as Snap-on. If it still fails, I would probably impact it before taking it to a shop to get it out. Some times the quick and rapidly rotating force is exactly what the threads need. but that's the last thing I'd do before taking it to a shop since it also comes with a high chance of massive fail.
Old Feb 24, 2010 | 11:10 AM
19Accord97's Avatar
I would say to keep spraying it with penetrating oil a couple times a day for a few days.
You DONT want that spark plug breaking and having bits of ceramic going everywhere.
Old Feb 24, 2010 | 03:30 PM
what would be the worst case scenario? im thinking ill need a new head or just put in a new engine. i could land a cheap F23 pretty easy.
Old Feb 24, 2010 | 04:03 PM
slomofo's Avatar
GDD Member
Worst case scenario would be some dumbass before you cross threaded the spark plug in which you'd be left with one of three solutions:
1. Run a thread chaser down there.
2. Cut new threads and insert a sleeve. (Due to Ford's shitty designed 4.6, 5.4, and 6.8 engines, EVERY autoparts store should have sleeves in stock)
3. Remove the head and have a machine shop fix it.
This is worst case scenario only though.
Old Feb 24, 2010 | 07:10 PM
Shazzy04's Avatar
As slomofo said those are the worst case scenarios, remember, dont be too hasty with letting the penetrating oil soak could cost you more money
Old Feb 24, 2010 | 07:24 PM
uberEFtuner's Avatar
Just checking, are you doing this with the engine warm right?
You could try an impact gun too.
Old Feb 24, 2010 | 09:03 PM
well im gonna mess with it til pay day. couple more days. im probably going to put a little bit of the penetrating oil so that i can still drive if i cant get it out. from what it seems like, im probably better off with a new head, or some sort of swap. G23 or swap the whole engine for an F23.
Old Feb 24, 2010 | 09:07 PM
nico.tico's Avatar
I had the same problem on a 95 civic I had one time. I was really afraid of messing something up so I just took the head off and took it to a machine shop. Dropped it off in the morning they told me to be back about noon, 30 bucks for the work.
Old Feb 24, 2010 | 11:49 PM
man i hope i get that lucky with the price.
Eg92h22Ek97
May 17, 2017 05:15 AM
scuffler
Mar 8, 2012 08:08 AM
gianinline
Nov 19, 2005 07:35 PM
bobdigital
Jul 6, 2004 03:30 PM
david90
Mar 30, 2004 03:55 AM
