Front end pieces i.d. (pics)
Old Feb 23, 2010 | 04:48 PM
unknown force's Avatar
Default Front end pieces i.d. (pics)
Trying to repair my front end, PO slid under the rear end of a truck and bent up the driver side some. I initially thought it was just the bumper but it isn'ttttttt
anyways here are the pics, i tried to find the front end pieces on like majestic but the only thing i can find is the bumper beam. not really sure what to search for? part numbers or a part name would be helpful
Old Feb 23, 2010 | 04:53 PM
junk95civ's Avatar
Default Re: Front end pieces i.d. (pics)
Wow that sucks man. Maybe try a junkyard?
Old Feb 23, 2010 | 04:55 PM
i've seen some cars on CL that are being parted out, i'm just trying to find out what the pieces are called/part number before i drive 40 minutes to the nearest junkyard
Old Feb 23, 2010 | 04:56 PM
eros18's Avatar
is there any pictures without the bumper?
you definitely need a grill. there should be more, remove the bumper then take pictures, not too close though.
Old Feb 23, 2010 | 04:57 PM
i have the grill. i'm talking about the metal piece that is right at the front that is bent down on the driver side. i already have new hood/bumper/fenders/grill and bumper beam i just need that metal piece.
Old Feb 23, 2010 | 06:45 PM
jcdimvic's Avatar
its called a radiator support, i would try and find an oem one. try the wreking yards. be sure to take a drill with a bit to cut the spot welds. I also recommend taking a matal chiesel and a BFH. You can also get repop ones on ebay
Old Feb 23, 2010 | 06:51 PM
JdmOdz's Avatar
good luck
Old Feb 23, 2010 | 07:20 PM
2000EX WhiteMagic's Avatar
This is what I found on Majestic Honda web-site. Hopefully it helps.
Part #
21172 001 OUTRIGGER SET, R. FR. SIDE
21176 002 PANEL SET, R. FR. BULKHEAD
21177 003 CROSSMEMBER SET, FR. (LOWER)
21178 004 STAY SET, BULKHEAD CENTER
21180 005 OUTRIGGER SET, L. FR. SIDE
21181 006 EXTENSION SET, R. FR. SIDE
21184 007 PANEL SET, L. FR. BULKHEAD
21185 008 EXTENSION SET, L. FR. SIDE
21189 009 BULKHEAD, FR.
Old Feb 23, 2010 | 07:48 PM
95soul's Avatar
I've seen much worse. Just remove the bumper, and take a rubber mallet and a small piece of wood, and beat it back up.
Old Feb 23, 2010 | 08:35 PM
Damn, I'm gonna try the mallet then haha. Is that not just a single piece then on the top? This just gets worse and worse
Old Feb 23, 2010 | 09:30 PM
alphalanos's Avatar
I agree its not that bad. pull the bumper and condenser and hammer it back.
Old Feb 24, 2010 | 11:03 AM
would something like this work?
http://cgi.ebay.com/ebaymotors/00-99...item439d926525
is it all bolted up or is it welded up? cause i don't have any way to weld if it is
Old Feb 24, 2010 | 05:00 PM
98civdx's Avatar
Master Detailer
core support is spot welded on not bolted that is a 99-00 and the front ends are differnt, but it may work for you.
bumper mount if narrower on 99-00 then 96-98 but i have heard of them working just fine.
a new oem ones tends to run 250 a new egay will run around 50+ but take it from me, i have a ebay core support and its garbage, 100% trash.
061000rr
Nov 21, 2013 08:43 AM
dfoxengr
Welding / Fabrication
34
Mar 5, 2007 09:50 AM
04accordV6
Mar 3, 2003 06:15 PM
B18C5-EH2
28
Jun 4, 2002 11:40 PM
