all lights on 96 hx wont turn on !!
Old Feb 23, 2010 | 10:27 AM
preludeboybmw's Avatar
Default all lights on 96 hx wont turn on !!
last night my buddys hx was working fine all lights were working until he went to pull a u turn and the lights in the front started flickering (h.i.d.s ) and all the other lights started doing the same he said he smelled something burning inside the car too.. we dont know wat to look for anymore .
dash lights inside dont work neither
all the fuses are good
just changed headlights swtich
check the wiring on the headlights and everything
brake lights work and the hids work when there connected strait to battery . so idk wat else to look for ..i need a digram
Old Feb 23, 2010 | 12:05 PM
ghost_xero's Avatar
Default Re: all lights on 96 hx wont turn on !!
maybe a wheel rubbed against an exposed wire....since you said it didnt happen till when u made a turn
Old Feb 23, 2010 | 02:09 PM
galvy22's Avatar
nope no exposed wires took the tires off and checked it out everything was fine.....what else should i do
Old Feb 23, 2010 | 10:04 PM
this sucks lol idk wat to look for besides a short behind the dash
Old Feb 27, 2010 | 03:17 PM
ghost_xero's Avatar
check the dimmer switch...it could be bad or burnt out from overload, my dash lights were iffy and i tracked it down to a bad dimmer switch, swap it and see what happens
Old Feb 28, 2010 | 02:25 PM
galvy22's Avatar
a few people said the same thing im going to try it tomrrow when im able to get a couple extra switches
Old Feb 28, 2010 | 03:09 PM
green99civic's Avatar
Timer Switch or perhaps is your relay bad?
LSteggyguy
12
May 15, 2016 03:37 PM
BLU CIVIC
Dec 29, 2010 03:31 AM
YouGotHacked
Honda Civic (2001 - 2005)
Nov 16, 2006 09:52 PM
mel
12
Nov 9, 2006 09:04 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
