Crome 1.5.3 and latest version of Freelog - How to make work?
I am looking for help to make Crome 1.5.3 and latest version of Freelog(1.093 I think) work from people that currently are using both. What I have is the honda tuning kit from Moates.
I have found information about this set up, but I am not able to make it work correctly.
I can set everything up with crome and comunicate with the ecu, but when I try to datalog with Freelog it seems to be working, but the values don't seem to make sense.
I am also not able to read the rpms and many other sensors. The only one that I remember that works is the ignition on and I think the tps. Is there a manual for freelog? I tried a quick search, but could not find anything.
Can someone let me know their current set up and configuration in freelog? I have tried one that I found here in ht, but it does not seem to work properly
I have a p28 chipped ecu. I have performed all the modifications necessary per all the threads that I found. I used the p72 program and followed instructions regarding the two plugins that need to be applied before loading the program to the ecu using the ostrich.
Any help would be appreciated.
Thanks
Thanks
You need to change the protocol configuration.
There's a thread about this on the pgmfi.org forum. Pictures and everything.
