FS/ MUSTANG NOTCH $6000
This is a mustang notch back, NO bondo, Painted flat black, Car is super clean, Optima cell battery, 4" cowl hood, Power steering delete, A/C delete, Smog pump delete, Mechanical temperature gauge, Mechanical oil gauge, Nitrous gauge installed, Fuel pump wired with relays to a switch, Fan wired to a switch with constant power to stay cool at the pits. Car runs very strong, Typhoon upper and lower intake, Cold air intake, Aluminum radiator, Blue led shift light with digital tachometer, 306 engine built for nitrous, Custom grind cam, Ported and polished heads, Walbro 255 fuel pump, Reinforced torque boxes, B&M short throw ripper shifter, 50/50 drag shocks in rear,Drag racing trick springs in rear, 90/10 drag shocks up front, All shocks are like brand new, New brake job up front, New master cylinder, BBK 70mm throttle body, Egr spacer with block off plate, Shorty headers, Custom stainless x-pipe, All exhaust is welded, Spintech super pro mufflers dumped, Aluminum driveshaft, 4.10 gear, Mass air flow converted, Performance clutch with aftermarket quadrant, Southside liftbar lower control arms, Weld draglite slicks and skinnies with my et streets on the back(with tubes) with not even 2 passes, Brand new front skinny's, Comes with extra set of black 10 holes with tires, Ford racing 9mm wires, Msd blaster coil, Msd cap and rotor, I also have the tinted lexan for the side windows also. Also have 1969 351 windsor rebuilt 5,000 miles ago, Block is good for 700 horse, With 1969 351w heads, Professionally ported and polished 2.62 race gasket matched, With comp cam roller rockers, Dual coil valve springs, This would come with the car. Its a retired NMRA drag car.Very fast WANT TO TRADE FOR NEWER MUSTANG, HEAVILY MODDIFIED CIVIC or 6,000. Over 1,600$ in rims and tires alone. CALL 219-808-4571, or email me with offers farmpolice2@aol.com.
they cant ban me long son.. i didnt do nothin but keep it real... fukk the haterz.. none of them will line it up so i can shut em up with my primered eg
I have 3 notch's my self. 1600 for wheels and tires? I paid 400 for my drag lites and 400 for brand new goodyear slicks and skinnies.
Whats the lift on that custom cam of yours?
And do you have paper work showing thats it was "built for nitrous", or is it just a stock 302 with bolt ons?
And how does that car have 50/50 and 90/10 shocks? Its either or not both
or u can text him and ask him hence y i left his number in the ad
look like i said not my car i posted it for a buddy he wrote the ad on craigslist and i just took and posted up here.. i will get him to clarify the **** but from wut i no the car is a NMRA car and it does have a shitload of work done to it...
ttt for you baker.
And to the OP Ill call your friend.
if n e 1 has questions on the car text dude the number is in the post... i cant stand the blue oval i just wanna see my dude get a more gas efficient ride
You should shut your mouth kid. The post got edited and i asked legitimate questions. I have 3 fox's and have a friend who is looking for one and a notch. So since this popped up i asked what cam is in it and if there's paper work for the motor. Im not gonna waste my time driving out to look at a stock 302. Go F off.
