how to install auto meter temp gauge
Old Feb 22, 2010 | 01:57 PM
jdmstyleEJ6's Avatar
Default how to install auto meter temp gauge
okay i have a 96 coupe i jus swaped a gsr in it and i was wondering if i could just install my auto meter temp sending unit were my stock one is or does the stock temp unit give a singnal to theecu has anyone done this i couldreally use any help thank you in advance
Old Feb 22, 2010 | 02:20 PM
DVDr's Avatar
Default Re: how to install auto meter temp gauge
Leave the stock one in place and install the aftermarket on to a spliter on your coolant hose line.
( or you can tap the block , but you would need to do a flush or tap near thermostat )
Old Feb 22, 2010 | 02:23 PM
DVDr's Avatar
Here is the part I was mentioning above,
Old Feb 22, 2010 | 02:40 PM
thank you
Old Feb 22, 2010 | 03:43 PM
also i have one more question does it matter were i put the splitter at and does it matter which hose i put it at should i put it close to the block
Old Feb 22, 2010 | 07:06 PM
bump
Old Feb 22, 2010 | 07:33 PM
DVDr's Avatar
I would use the bottom hose as it feeds the motor with the fresh/cooled coolant and there is always flow.
The top rad hose gets coolant when the thermostat is open.
Cliff notes: Use bottom hose in my opinion.
PINKS
Mar 12, 2006 12:03 PM
VTECAcuraGSR
Jul 25, 2003 05:31 PM
VTECAcuraGSR
Jul 21, 2003 01:55 PM
