JDM ITR axles on the civic hubs
Old Sep 6, 2002 | 09:57 PM
Nameless RB26's Avatar
Default JDM ITR axles on the civic hubs
Can you guys tell me if the grooves on the JDM ITR axles will fit into the civic hubs? (99 DX civic)
And if I can use the civic spindle nut aswell?
Sorry if it's in the wrong forum. Someone can move it if it's too big of a deal...
Thanks-
Old Sep 6, 2002 | 10:18 PM
sgT's Avatar
sgT
Default Re: JDM ITR axles on the civic hubs (Nameless)
No. they will not fit. You need US integra axles.
Old Sep 7, 2002 | 09:27 PM
Default Re: JDM ITR axles on the civic hubs (sgT)
Ok thanks.
Is there going to be any difference between axles though? LS/GSR/ITR?
Old Sep 7, 2002 | 09:32 PM
migs's Avatar
LS/GSR/ITR axles are all the same, they all have ABS
RS trim model is only different because it doesnt have the ABS teeth counter ring around the axle.
As for your question about the axles. Answer to it, is YES and NO.
The pre-98' Integra axles will work fine and use the 32mm axle nut.
The 98-01 requires you to use a JDM axle or a custom axle and utilizes a 36mm axle nut.
One of my friends bought a JDM ITR suspension and didnt know he could not use the USDM Integra Axle. He had a shop piece it together and they said they had to use a 92 Accord Axle? Not too sure on the exact specs.
Hope this all helps.
Old Sep 7, 2002 | 09:49 PM
sgT's Avatar
sgT
Default Re: JDM ITR axles on the civic hubs (Migs)
ALL JDM ITR axles use the larger accord/prelude hub/spline.
Easy way to make jdm itr axles is to use integra axles and put on the outer CV from
a prelude or accord.
All 94+ integra axles are the same.
Old Sep 7, 2002 | 10:08 PM
migs's Avatar
Wrong, 98+ JDMITR use the 36mm. Pre-98 JDMITR uses the 32mm axle nut
All CTR use 32mm regardless of the year
Old Sep 7, 2002 | 10:27 PM
Sorry, still a little confused.
This is for a 99 JDM ITR into a 99 DX.
ALL I need to do is get a set of usdm Integra axles and I'll be fine right? And not the RS.
Please be really clear with me, I have to do things quickly to get this swap done before college classes start, so I don't have time figure things out. Maybe just tell me exactly what to do.
Old Sep 7, 2002 | 10:29 PM
migs's Avatar
99 JDM ITR suspension will require you to use a 36mm axle nut. So, you have to get a hold of JDM ITR axles or have a shop out here in US customize you an axle.
Old Sep 7, 2002 | 10:31 PM
I have the JDM ITR axles that came with my engine. (complete swap)
I was basically wondering if they would work fine fitting into the civic hubs with the proper nut.
Come swap day, I have to make sure everything will fit because I have to drive the car away that day.
Thanks for your help, I do appreciate it. Just gotta be sure..
EDIT: I'm not swapping suspension setups.. just swapping engine.
[Modified by Nameless, 11:32 PM 9/7/2002]
Old Sep 7, 2002 | 10:35 PM
migs's Avatar
Whats the EXACT setup you are going to run.
If you are using the Civic Hubs, they can ONLY accomodate the 32mm axle nut.
Old Sep 7, 2002 | 10:40 PM
I am putting a '99 JDM ITR engine into a '99 Honda Civic DX hatchback.
All I will be doing is swapping the engine in. That's it. Nothing more.
I have the JDM Integra axles sitting with my engine. (the original ones)
I just wanted to know if they are going to work with the civic hubs.
From what I have gathered, I just need to use a set of usdm Integra axles. Correct?
Old Sep 7, 2002 | 10:44 PM
migs's Avatar
94-01 USDM Integra Axles, thats your answer.
Old Sep 7, 2002 | 10:46 PM
haha thanks.
I think I just used up my 5 posts of the 24 hours.
[Modified by Nameless, 11:47 PM 9/7/2002]
Old Sep 8, 2002 | 08:52 AM
Mike M's Avatar
Founding Member
What Steve Originally Said
Old Sep 12, 2002 | 06:17 PM
Default Re: JDM ITR axles on the civic hubs (Mike M.)
Sorry to bring this post from the dead.. but my axles for my 99 JDM ITR engine are 32mm. I checked it today.
I think they changed to 36mm in 2000.
Can someone tell me I'm wrong?
o-eazy
May 15, 2008 02:28 AM
vtakef
Jan 21, 2008 07:08 PM
DC2 to AP2
Jul 4, 2004 04:08 PM
Boosthead
May 20, 2004 12:34 PM
GSRacer
Dec 27, 2001 02:39 PM
