how to ID a ITR head?
Old Feb 22, 2010 | 11:04 AM
punkracer's Avatar
Default how to ID a ITR head?
buying an ITR head. any castings that will show thats its an ITR and not a B16..?? i know where the year marking is....so if its a 95 and lower its a b16. but if its a 96 to 98, 00-01 it could be....
any diffrent casting in a 96-97 itr head and a 98,00-01 itr head? i know the cams got changed do they still got the bigger throat opening (.010 as per omin vid) in the valve?
Old Feb 22, 2010 | 01:10 PM
punkracer's Avatar
Default Re: how to ID a ITR head?
no one knows? i dpont wanta double post this in the ITR or tech section....but think i will need answer....bump
Old Feb 22, 2010 | 01:23 PM
Hybrid96EK's Avatar
Well, to tell you the truth, this is how I identify and R head. You need to look into the INTAKE side ports. Right at the throat of the port, it should be mildly ported. Nothing big, but you can see the difference. Intake valves have recuded stem diameters compared to other B heads. Its noticeable, take a look. If the head hasn't been washed/tank then it should have GREEN paint on the edge where the dist bolts up. It will be stamped "P30" on that side also. The casting marks are usually "PR3-3".. I think I recall reading there are some "PR3-2" castings also. Check the year of the head. Obviously if its dated "89" then it can't be an ITR head. Check for dual springs on both the intake and the exhaust side. I seem to recall the colors yellow and light blue for the paint markings on the springs... but sometimes its very difficult to see with oil. Hope this helps.
Old Feb 22, 2010 | 01:32 PM
punkracer's Avatar
awsome thanks man....ill look... anyone else would like to chime in that would be sweet...
Old Feb 22, 2010 | 01:51 PM
Hybrid96EK's Avatar
I just did some research on it myself.. Looks like the "PR3-3" casting isn't a sure thing. About the only thing you can be 100% on is looking for the "port work" on the intake side and the green paint. The green paint is 100% if it hasn't been washed off... the portwork is obvious also.
Old Feb 22, 2010 | 08:15 PM
Muskie Man's Avatar
I believe my B18C5 head has the code "PR3-4" cast into it. Sadly its buried in snow right now so I'm not able to confirm. Pretty sure though.
umair
Feb 23, 2009 07:09 PM
Th3savinday
Dec 14, 2006 07:32 PM
JDMlyfestyle
Jan 14, 2004 03:59 PM
nwdave
11
Jul 21, 2003 02:56 PM
are_sicks
Jan 4, 2002 12:38 PM
