Code 59 trouble? Whats causing this? rpm problems look inside
Old Feb 22, 2010 | 09:42 AM
80 dolla crx hf's Avatar
Default Code 59 trouble? Whats causing this? rpm problems look inside
I know its a cylinder #2 misfire. Cant seem to figure out why my car is doing it.
Its the tdc code?
ITs a 2000 integra with a chipped ecu wired to obd1
Is it the distributor? the motor is obd1 as well.
It is running a new obd2 dizzy.
Anytime i run the blue(tach wire) wire on the dizzy to the tach it works up to 3k and stops working for a week only to work for a few mins? is the dizzy bad?
Thats the only way the tach works.
Old Feb 22, 2010 | 06:29 PM
Default Re: Code 59 trouble? Whats causing this? rpm problems look inside
Need help
Old Feb 23, 2010 | 07:13 PM
comeon help me
Old Feb 24, 2010 | 05:50 PM
about to start paying people
Old Mar 2, 2010 | 08:41 AM
any one?
Old Mar 2, 2010 | 08:55 AM
silv00teg's Avatar
Its the tdc code?
if i'm not mistaking if the motor is obd 1 and so is the ecu you should probabaly be using an obd 1 dizzy
slow_low_eddie
Mar 2, 2014 12:06 AM
catchdz
Nov 29, 2011 10:47 AM
efjones9
17
Aug 3, 2009 07:27 PM
2Point3
May 20, 2009 05:18 PM
bseriesEF
Jul 27, 2006 02:21 PM
