My a/c or heater in my car does not work at ALL!?
Old Feb 22, 2010 | 09:16 AM
Zendos's Avatar
Default My a/c or heater in my car does not work at ALL!?
i mean period, nothing works. id turn the **** from low through high, from hot to cold, neither of them work. the light for the different settings does not work as far as like, the front and back defrosters, the front blowers, passenger and driver blowers, feet. i mean seriously nothing at all. no hums or anything. i drive a 1997 honda accord. what could this be.
Old Feb 22, 2010 | 10:14 AM
davey5300's Avatar
Default Re: My a/c or heater in my car does not work at ALL!?
Bad ****, bad Climate control circuit board, bad blower motor, bad fuse, bad wire somewhere..thats all I can think of
Old Feb 22, 2010 | 12:12 PM
Atreidies's Avatar
Did you recently pull your center console out? Could be disconnected wires. If you didn't, I would check fuses first. With none of the controls working or even lighting up, I would think it's more than a bad rheostat or blower.
Old Feb 22, 2010 | 07:57 PM
busha61067's Avatar
like they said fuse or loose wire
Old Feb 22, 2010 | 08:36 PM
Zendos's Avatar
what are the symptoms of a blown blower relay
Old Feb 22, 2010 | 10:09 PM
Atreidies's Avatar
Blower doesn't work. Which is also the symptom of a bad blower motor, a bad blower switch, loose wiring and a blown fuse, so don't assume it's the relay.
Old Feb 22, 2010 | 11:21 PM
19Accord97's Avatar
If nothing is working, lights, a/c, heater, then either its disconnected or fuses are blown.
Check the fuses, its easy.
Old Feb 25, 2010 | 06:34 PM
Shazzy04's Avatar
If its not the fuses, check the wires, may of forgotten to reconnect.
let us know
Old Jun 26, 2014 | 09:45 AM
galvanjosh24's Avatar
I have same problem on my 97 crv please help
civicej897
12
Apr 4, 2013 08:23 PM
racingcrx
Dec 19, 2008 01:26 AM
Civic_4life
Dec 17, 2008 10:57 PM
johhnyu2
Apr 1, 2008 11:38 AM
Jer'rome
Feb 13, 2005 12:59 PM
