GSR Rebuild...have some questions.
Old Feb 22, 2010 | 07:18 AM
OEMJDM's Avatar
Default GSR Rebuild...have some questions.
I am about to rebuild my b18c bottom end, which I will be mating to a b16 head. After some reading i have decided to stick with gsr crank and rods instead of the LS crank and rods. I was planing to shot peen the ls rods, using ITR pistons. Since I will be using the GSR crank, do you guys recommend that I shot peen the gsr rods?
I will be using all OEM parts except for ARP rod bolts. I am hoping to make around 180-190 WHP. Besides the ARP rod bolts, are there any other parts I should replace if I will be using OEM parts for the bottoms end?
Since I will be mating the b18c block to a b16 head, Which head studs and main studs would i use? I am planning to use ARPs as well. Just want to make sure I order the correct parts.
Thanks
Old Feb 22, 2010 | 07:27 AM
93egSLEEPER's Avatar
Default Re: GSR Rebuild...have some questions.
Dont worry about touching the GSR rods, they will be fine.
Use GSR head studs, not B16.
boost4life
Jun 10, 2011 11:46 PM
Superqwak
May 24, 2011 06:28 AM
d16turbocoupe
May 27, 2009 10:07 PM
leroyb
May 6, 2009 07:13 PM
white4doorsi
Mar 15, 2008 05:35 PM
