new problem car running slow
are the revs cutting out at about 3 grand? are you throwing any codes? is your timing (both belt and ignition timing) set correctly? any recent work done to the car? we need more info
lets see turning on my car it acts weird....like when i turn it on i kinda dont want turn on then the idle rate is off..... when i leave the car on for 10 mins then i step on the gas it shuts off car revs slow....i can step on my gas pedal all the way but it will jsut go up slowly.... it wont just jump.....
it maybe the plugs ill try changing it tomorrow or something i guess thanks guys hopes this solves the problem and yes i am getting a code 8 short blinks which indicates TDC Sensor?
