fuel pump not kicking on
Old Feb 21, 2010 | 09:32 PM
stickman78114's Avatar
Default fuel pump not kicking on
just swapped my new dohc zc into my crx
not getting fuel to engine, not hearing the buzz frm the fuel pump.
relay clicks, also tested w/ my bros wrking relay still no fuel pump buzz.
i am getting spark. ima try hard wiring it in the morn. if its not wrking gonna replace the pump. my question is if it does start when i hardwire it, what could keep it from kicking in if it's not the main relay???
Old Feb 21, 2010 | 09:46 PM
Default Re: fuel pump not kicking on
also i am getting spark so i'm pretty sure it's isolated from somewhere after the main relay
Old Feb 21, 2010 | 09:48 PM
EFRue57's Avatar
did you change any of the wiring during the swap? for example did you have to convert from dpfi - mpfi or did you do an obd0 - obd1 conversion or anything like that?
Old Feb 21, 2010 | 10:05 PM
nah, i have an 89 si. the swap was really straight forward.
Old Feb 21, 2010 | 10:08 PM
EFRue57's Avatar
yeah that would be a pretty straight forward swap, lol. i'll see if I can't come up with something tomorrow. getting kinda late and doing the whole head nod thing about to pass out here at the computer. maybe by then you will have tested the fuel pump by then and will either have found out the problem or at least eliminated another possibility, lol.
Old Feb 22, 2010 | 02:14 PM
figured it out! crimped wire!
datonefoo1
Feb 8, 2008 12:29 PM
94delsol6428
Dec 27, 2006 07:06 PM
si 1
Dec 21, 2005 11:03 AM
ROK801
Oct 31, 2005 07:28 AM
bigbacon2
Jul 31, 2005 05:34 PM
