Suspension & Brakes Theory, alignment, spring rates....
newb+skunk2
Old Feb 21, 2010 | 09:12 PM
freeagent's Avatar
Default newb+skunk2
ok so i just picked up some skunk2 springs im there just called skunk2 adjustable springs?
http://www.skunk2.com/suspension-2.php?code=COVADJ
sorry im not sure if there very good or not, i got them for dirt cheap so would these be ok for a slight drop or would you use something else?
basicly are these better than the ebay ones? cause they look very similar except the back ones im assuming look different..
sorry for the newb question but could find anything on these specific springs,
oh ya current setup is on 92 4dr obx springs(full length) on tokico blues
Old Feb 22, 2010 | 07:24 PM
STOCK_SOHC_DX's Avatar
Default Re: newb+skunk2
These actually let you know your spring rates unlike most ebay kits, also they will most likely blow your blues in no time.
Old Feb 22, 2010 | 08:30 PM
freeagent's Avatar
really? thats gonna suck..can you explain to me why?
and also i dont plan on going lower just want better quality than what i already have
Old Feb 22, 2010 | 08:35 PM
johnbizzel's Avatar
there good u should be fine...
Old Feb 22, 2010 | 08:47 PM
freeagent's Avatar
ok so i have one that says there good and one says they are bad but no explanations for either..
please explain reasoning
thats why the other threads i did find wernt helpfull they just simply stated yay or nay
and thanks for the help so far
Old Feb 22, 2010 | 09:25 PM
Tokico blues aren't valved for that aggressive of a spring rate.
Old Feb 22, 2010 | 09:48 PM
freeagent's Avatar
ok good to know..
so would kyb agxs be a slightly better choice when they do blow out?
sorry i know there are like absolute good brands but as im currently low on funds and trying to use the best parts i can get im doing it the best right way i can..
thanks for the info again
Old Feb 23, 2010 | 10:20 AM
kristo's Avatar
Loved
Originally Posted by STOCK_SOHC_DX
KYB, Tokico don't warranty their shocks if paired with aggressive drop springs. Koni's do and so do the skunk2 but skunk2 warranty is only 3 months.
Originally Posted by idrivesideways
koni str.t is far superior to the tokico blue and the same $300 shipped. not only do the konis have stronger valving they actually will provide a lifetime warranty. the str.t is basically the sport set on soft.
it's hard to suggest the AGX even though they are a good shock, it's just koni sports are $450 and the AGX's are nearly the same.
Old Feb 23, 2010 | 01:26 PM
freeagent's Avatar
ok good to know so what if i found a used set of konis?
would this void warrenty? and is it rare for konis to blow with agressive springs?
Old Feb 23, 2010 | 01:31 PM
kristo's Avatar
Loved
Koni warranty is only for original buyer (like most if not all companies).
Koni is very good but not for low-low setups, then you must use extended top hats.
Old Feb 23, 2010 | 01:45 PM
freeagent's Avatar
alright thank you for the explanation.. im very sure youve helped alot more people than just me in this thread so thanks again
eK_HatchY
20
Dec 7, 2009 11:50 PM
tico
Jul 23, 2008 08:50 PM
HondaC03
Honda Civic (2001 - 2005)
Jun 7, 2008 11:43 PM
allricedout
Suspension & Brakes
Jan 15, 2007 01:17 PM
aleks77
Jun 18, 2005 07:02 PM
