My B18C1 mild build on a budget.. l
Old Feb 21, 2010 | 05:46 PM
94 EG GSR's Avatar
Default My B18C1 mild build on a budget.. l
Whats up guys... I have a 94 eg with a gsr in it.. heres what i got done to it and im almost done putting it back together(just a couple more days).. let me know what whp you think i should roughly have.. Thanks for reading
94 b18c1
full ported head with bowl work
head milled .30 to up compression
blox im
blox B cams
blox dual vs and titanium retainers
jdm itr header
no cat with 2.5" exhaust
walbro fuel pump
p28 tune on crome
hondata im gasket
ngk wires
act 4 puck
act 8.8 flywheel
act extreme pressure plate
aem cai
stock healthy block
type r tranny
im hoping i hit 200whp.. let me know what you think
Old Feb 21, 2010 | 08:56 PM
OrangeTeggy's Avatar
Default Re: My B18C1 mild build on a budget.. l
when getting it tuned?
Old Feb 21, 2010 | 09:43 PM
Phantom Integra's Avatar
I made 205hp the wheels with blox b's cam on ls vtec motor
Old Feb 21, 2010 | 09:45 PM
and my head is not mill or ported so u going to c some nice # let me know what u make on the dyno.
Old Feb 21, 2010 | 09:47 PM
94 EG GSR's Avatar
Is that on a stock block
Old Feb 21, 2010 | 09:49 PM
94 EG GSR's Avatar
I'm putting it back together this wk.. I get my head Tuesday and I have everything else.. Then I should get my income tax in the next 2 wks then off to the dyno and I'll post my numbers
Old Feb 21, 2010 | 09:54 PM
94 EG GSR's Avatar
Also I'm in northern Cali and I was gonna go to Dave at DNR to tune it but if anyone knows somewhere better or has other suggestions for a good tuner in nor cal please give ur opinion
Old Feb 22, 2010 | 09:13 AM
AllmotorGSReg's Avatar
those cams would benefit from some higher compression pistons then stock
Old Feb 22, 2010 | 12:01 PM
94 EG GSR's Avatar
ya i know just cnt afford it right now thats why i milled the head to go from 10:1 to 11:1
Old Feb 22, 2010 | 12:57 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
just make sure you don't have p2v clearance issues. should be fine though.
Old Feb 23, 2010 | 12:27 PM
no i have usd type r piston in my block that put me to 11:1 so u to b fine. u should c 180hp to 195hp depends on tuner my friend setup like ur's made 180 to the wheels
Old Feb 23, 2010 | 12:31 PM
And with that milled ur comp. will be close to 10:6 thats going to help u with the B's
Old Feb 23, 2010 | 12:34 PM
n1taboo's Avatar
nice set up....need a good ecu tuning and should put out about 200hp
Old Feb 28, 2010 | 07:43 PM
94 EG GSR's Avatar
got it all back together and its not tuned yet but it feels like a beast already.. its alot faster than before and i should get it dynoed this week
Old Mar 1, 2010 | 05:37 AM
try no
Old Mar 2, 2010 | 05:33 PM
94 EG GSR's Avatar
Hater in da house but im not suprised... id smash ur ls-v wo a doubt lol
Old Mar 3, 2010 | 07:20 AM
my other post did not post that did not come out right my bad man just try to to help. but if u think u can low 12's high 11's then u can beat me my set up is changed a little bit just wana c u make good # :boom:
Old Mar 3, 2010 | 08:19 AM
092eg6's Avatar
u should hit or at the least be close to 200whp with the set-up, but im sure with higher compression pistons should get u there no problem!
Old Mar 3, 2010 | 12:11 PM
the most i seen was 190hp tops
andyg2333
14
Jun 29, 2013 07:59 AM
xialbyix
38
Jun 5, 2008 03:31 AM
spoonhatchblack
22
Oct 15, 2007 09:07 AM
JoeB18R
31
Mar 4, 2005 08:31 AM
Speed_Ricer99
Apr 15, 2002 09:59 AM
