Need your guy's help.....fume problem
I recently noticed I feel "high" when driving long distances.I believe it could be one of many things.Evap canister isn't working,rubber plug on the firewall aren't all sealed.Gas tank is leaking fumes/seal is leaking.If you've dealt with anything similar to what i'm describing please help.I'm replacing the exhaust manifold gasket tomorrow as well. Car is a 91 Civic.
...u drive a 20+ year old car, and your worried about getting 'high' on fumes? If its gonna matter like that, then fix ALL the leaks, or just let it go. open ur windows and leave them leaks alone till something brakes.
I've owned 5 Ef's and never had this problem.I'm looking for help not advice.thanks.
my guess would be the IACV or the o2 sensor but if someone could confirm what the code that is being thrown is,that'd be greatly appreciated.
I'm goin to replace the exhaust manifold.Lower the gas tank and check for any loose hoses or cracks and then go from there.With the chasis having 390,000kms i'm sure there are a few Oem parts that need replacing.Thanks for your help masterEf
the code its throwing at you is regarding you cata im assuming also try replacing your whole exhaust system go to a muffler shop it would cost like 100-200 bucks for new piping just bring your ow muffler and cat
xxi2icexx
15
Aug 13, 2010 01:59 PM
Dropped90Integra
Jul 14, 2005 08:33 AM
hadehatch
Apr 20, 2004 09:44 PM
getting one in the next week or so...
