what bolts to use on the turbo?
(1) there is a hole next to the turbonetics plate on my t3/t4 and i have no idea what to do with it.
(2) what kind of bolts should i use to bolt my manifold, turbo and wastegate together?
size, grade, washer or no washer
take your manifold and go to home depot and find the correct threads, it'll be metric for sure...
get a grade 8 bolts
for WG, DP and etc, is 8x1.25mm
get a grade 8 bolts
the whole on your turbo might be where a threaded fitting goes to run a hose to your wastegate . would have to see a pic to be sure .
