94 GSR question - I would have told you it's about fuel pressure if I read the rules
Old Feb 21, 2010 | 04:59 PM
cghorr01's Avatar
Default 94 GSR question - I would have told you it's about fuel pressure if I read the rules
So i got my GSR swapped in finally and got it running and i was hoping someone here could give me an idea of what kind of fuel pressure a GSR should be pushing. The motor has an edelbrock victor x intake manifold, a edelbrock 68mm throttle body, dc 2 piece headers, and intake, 440cc injectors, a venom fuel rail, aem pressure regulator, 255 walbro fuel pump, nology hotwires, ZEX nitrous plugs, and a ZEX wet 75 shot kit. If someone could help me out Id be eternally grateful. I had it set perfect in the last shell the motor was in but it got crushed by a falling tree so while the motor was out i took everything apart, cleaned it, put all new seals and stuff in it and then put her back together.
Old Feb 21, 2010 | 10:20 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 94 GSR question - I would have told you it's about fuel pressure if I read the ru
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Feb 22, 2010 | 06:37 AM
dpetro1's Avatar
just set it to stock fuel pressure...
FPR READING WITH HOSE OFF AND PINCHED
48-54 PSI
WITH HOSE ON
38-42 PSI
also you will need a chipped ecu and tuning software to control those 440's and nitrous. didnt see that mentioned anywhere
Old Feb 22, 2010 | 08:14 AM
cghorr01's Avatar
48-54 PSI
WITH HOSE ON
38-42 PSI
The zex has a module that controls the nitrous system automatically
nicknack25
May 17, 2019 07:17 PM
kroy546
Apr 12, 2012 07:20 AM
one8toh8
Feb 4, 2005 08:50 AM
SleepinAround
Jul 16, 2002 05:12 AM
