JDM DOHC ZC Fuse Diagram
I need to put fuses in my dohc zc swapped crx but i cant find the fuse diagram for the jdm crx, i have the fuse diagram underneath the dash for the stock motor but i know the fuses have to be different dont they, different motor = different fuses?
Yep. Same thing. Think of it this way, your DOHC ZC is just an A6 with two cams and a sensor on the exhaust cam instead of inside the dizzy. Everything else functions just the same as an A6.
To the OP....are you aware that in Japan, the dohc zc engine came in civic's and crx's which were the known as the Si model!
Same fuse box...the engine uses the same sensors, why would a sensor be any different, all they do is just read signals.
Yea i was aware the motor came in the japanese crx originally and that it has the same fuse box, i just didnt know if i was supposed to have different amp fuses than what my stock motor called for but thanks for the help.
Jordan_abbott90
34
Jun 30, 2013 09:08 AM
