B20 VTEC: Pump Gas Dyno Tune - 187whp 140 wtq
Quinn brought us his B20 VTEC CRX for a Crome Gold tune.
The car came to us with a street tune on an VAFC. The base ignition timing had been advanced until the distributor was locked out, and the AFR's were dangerously lean.
Here is the setup:
B20B Block
12:1 Pistons
Eagle Rods
GSR head
Blox intake manifold
Type R cams
DC Header
Stock Cat
2 1/2 Exhaust
Tuned on Crome Gold
Here is the tuned chart and the "street tune" chart.
Plans are to switch to a Bisimoto Header through us and retune on E85.
Here is the setup:
B20B Block
12:1 Pistons
Eagle Rods
GSR head
Type R cams
DC Header
Stock Cat
2 1/2 Exhaust
Tuned on Crome Gold
It wasn't an issue.
Usually, it's an issue when either the dip stick pop's out or you can actually see oil mist race out of the crank case vent. There was none of that in this setup.
Regardless, you bring up a good subject. There might be an extra 2 or 3 whp with the right ventilated catch can tapped into the valve cover.
Im curious to see this dyno'd open header for a power comparison. A nicer header and open exhaust will probably benefit it as much as a cam upgrade at this point. Even with cams it may still not make the best power because its not flowing freely.
Any cam timing adjusted on this or just stock gears?
What is the ignition timing?
I meant timing that was set at an idle from TDC. How many degrees was it advanced? I think a mix of cam timing+ignition timing with the setup listed right there would get closer to 195ish whp. A better header and exhaust would make 200whp+. then from there it would only get better with cams and whatnot.
Honestly, I don't recall what base timing was. Base timing makes little difference in this case since we are able to advance or retard away timing via Crome Gold. Ignition values are already optimized an no more could safely be squeezed out. I agree, cam gears may squeeze some more out of it, along with the bisi header, E85, etc. Should be fun.
Post up again after the part upgrades please
also pushing for a dyno comparison between premium vs e85
Cool deal.
We will definitely post up after the upgrades.
Not a bad idea to do a comparo vs E85. I think we may just do that if time permits.
On a different note, I just finished installing a 2nd fuel fuel pump on my setup. We'll be doing a 24psi pump gas vs 24psi E85 on a built K20z1 w/ full-race GT35R within the next couple of weeks when I'm able to get a brake from tuning. Should be fun as well, and informative.
Most tuning systems allow you to custome tune the timing maps along with the fuel maps. That's why tuning systems add so much more power and reliability over someone running a stock ecu with a FPR added.
________
VAPOR GENIE REVIEW
its windows 2000 to windows xp. will both work? sure. are they equal? not at all.
________
HONDA ACCORD HYBRID
So if some jump off a bridge then I should as well? Nothing against the other 2 platforms which by me, are great platforms as well but you are still speaking in general terms. Give specific technical facts or your comment is baseless. You state on your site that you've been working with the general version (Crome Pro) and not the dealer version (Crome Gold). Crome Pro may be "$100 or whatever" but Crome Gold certainly isn't. If you're going to make a comparison, use apples to apples.
this is just my opinion and i just happen to know there are many other very established tuners who feel the exact way i do. There is no point in using crome or crome gold when i have paid to be a tuner for ectune and neptune which are on another level than crome. Full tech support goes a long long way.
________
Extreme Q Vaporizer
I'm sure there are tuners that feel the same as you do. Just like there are those that use Crome Gold on a daily basis and put out proven results.
Let's assume that Crome Gold can't retard timing. Apparently you took that risk quite a few times according to the charts on your site. Why not refuse Crome work back then and demand something else or Hondata? Nothing against you or the choices you make but please, spare me the cynicism. Regardless, how do you explain the smoothness of this chart with smoothing set at 3? As a tuner, I'm sure you know what pre-detonation looks like on a chart and you surely know that this chart can easily pass for a smoothing of 5.
This customer was tuned the same day as Jesus. Direct link to the thread: https://honda-tech.com/forums/forced-induction-16/b18c-60-trim-garrett-e85-dyno-tune-422-whp-294-wtq-2731601/
This customer was tuned the same day as Jesus. Direct link to the thread: https://honda-tech.com/forums/showthread.php?t=2731601
I'm not calling you anything for using crome. Just stating my opinions. Not all opinions are going to be something you want to hear, as that is life.
I will never be a hondata dealer or support them and i will do my best to steer any customer that comes to me with hondata away from it to the systems i use. Hondata is a great great software, like neptune and ectune. But as a company, they can stick it where the sun doesnt shine.
At least you got the guy away from the vafc......unfortunately some people have to learn the hard way.
________
TOYOTA P ENGINE SPECIFICATIONS
