Brake Lights aren't working, Need Help ASAP
So suddenly out of the blue about 2 days ago, while driving I press the brake and every single time the open door + seat belt lights and sounds will go off until I take my foot off the brakes; on top of that my brake lights don't come on at all. It's super annoying! I have looked & checked out the wires that leads from the button which the brake pedal presses on to turn break lights off and nothing seems out of place.
Any ideas or suggestions?
its in the fuse box under the hood, I know it probably isnt a fuse but you should always check them., I'm just trying to get you to give us some info. diagnosing problems over the internet isn't easy, all the info you can provide helps.
actually it looks like it is a fuse ha ha https://honda-tech.com/forums/showth...ght=brake+horn
moral of this thread ALWAYS check your fuses before posting.
are either of ur tail lights burned out by chance if so ur shorting somewhere. ur probably shorting to ur door and seatbelt lighting and sound. so find a diagnostics book and find those wires and test for continuity in each of those circuits. bet you'll find ur prob there
MR Rodgers
Jan 5, 2009 02:32 PM
FullMetalJacket
12
Apr 29, 2003 10:07 AM
